1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: power off/on ioc recovery
From: "Tran, Phi Dung via Tech-talk" <[email protected]>
To: "Pearson, Matthew" <[email protected]>, Mark Rivers via Tech-talk <[email protected]>
Cc: Kevin Battaile <[email protected]>, "Myers, Stuart F" <[email protected]>
Date: Fri, 19 Dec 2025 16:57:49 +0000
  Hi Matt,
Thank you for the detailed response! Your insights were very helpful.
  Findings:
  1. system() command registration: You're correct - system() is NOT registered in our galil.dbd file, which explains why it wasn't working. I confirmed this by grepping the dbd file.
  2. RSTM field: My motor record does NOT have the RSTM field (caget XF:19IDC-ES{Tbl:1-Ax:HU}Mtr.RSTM returns "not found"). We're using Galil-3-0/3-6 with an older motor record version (pre-R6-11).
  3. Autosave configuration: Confirmed we're saving DVAL (in galil_positions.req) correctly.
  Solution Implemented:
  Following your suggestion, I implemented the bash wrapper approach:
  - Renamed original st.cmd → st_ioc.cmd
  - Created new st.cmd as a bash script that:
    a. Runs python3 generate_restore.py to auto-generate the restoration script
    b. Executes st_ioc.cmd to start the IOC
  The position restoration now uses SET mode after iocInit() to update the controller position without motor movement. This approach works reliably after controller power cycles, whereas pass0 restore alone
  failed (controller position overwrote the restored DVAL during initialization).
  Testing Results:
  - ✅ Controller power cycle → positions correctly restored via SET mode
  - ✅ No motor movement during restoration
  - ✅ Both VAL and RBV updated correctly
  Question:
  Is there any concern with using SET mode + hardcoded values (auto-generated from autosave file) versus relying on pass0 restore with RSTM=2? The bash wrapper automation works well, but I'm curious if upgrading
  to a newer motor record with RSTM support would be beneficial for other reasons.  However, I do not have permission or authorization to upgrade.
  Thank you again for your help!
Alex
Sent: Friday, December 19, 2025 11:35 AM
To: Tran, Phi Dung <[email protected]>; Mark Rivers via Tech-talk <[email protected]>
Subject: RE: power off/on ioc recovery
Hi, For the system command, there is documentation on it here: https: //docs. epics-controls. org/en/latest/appdevguide/IOCShell. html that explains you need to add the function registration to the database definition file. Was that done? For your
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd
https://docs.epics-controls.org/en/latest/appdevguide/IOCShell.html
For your work-around, it could be automated by instead of executing the IOC st.cmd file directly to start the IOC, execute a bash script that first runs the Python program, and then the IOC st.cmd.
However, autosave should be working for the position restore. Can you us which version of the motor record you’re using? And does it have the RSTM field? The RSTM field was added in order to improve the options regarding position restore:
(0:"Never", 1:"Always", 2:"NearZero", 3:"Conditional")
RSTM=2 is the default, and that reproduces the old behavior of restoring the position only if the controller position is zero (+/-MRES). So, make sure RSTM is not being set to 0.
There may be a version of the motor support module where the autosave restore method was changed, and before RSTM was added.
For some controllers and drivers you may need a short sleep (1s) after loading the driver and before executing the autosave functions and iocInit.
Also make sure you’re autosaving DVAL and not VAL.
Cheers,
Matt
From: Tech-talk <[email protected]> On Behalf Of Tran, Phi Dung via Tech-talk
Sent: Friday, December 19, 2025 10:30 AM
To: Mark Rivers via Tech-talk <[email protected]>
Subject: [EXTERNAL] power off/on ioc recovery
Hello, I'm trying to run a Python script from within my IOC startup script (st. cmd) to auto-generate a configuration file before iocInit(). However, I'm finding that the system() command is not available in my EPICS build. Background - Motor
Hello,
  I'm trying to run a Python script from within my IOC startup script (st.cmd) to auto-generate a configuration file before iocInit(). However, I'm finding that the system() command is not available in my EPICS build.
  Background - Motor Position Restoration Problem:
  I need to restore motor positions after a Galil motor controller power cycle. I discovered that:
  - Pass0 restore alone works when only restarting the IOC (controller stays powered on)
  - Pass0 restore fails when the controller is power cycled - the controller resets to 0, and motor record initialization overwrites the restored VAL field with the controller's position (0)
  My Solution:
  I use SET mode after iocInit() to restore positions without motor movement. To avoid hardcoded values, I wrote a Python script (generate_restore.py) that reads the latest autosave file and generates the restoration script with
  current saved values.
  What I'm trying to do:
  Run this Python script automatically during IOC startup (before iocInit) to ensure the restoration script always has the latest saved positions.
  What I've tried:
  system("cd /path/to/script && /usr/bin/python3 generate_restore.py")
  Error received:
  st.cmd line X: Command system not found.
  Also tried:
  - shell "command" - Command not found
  - ! command - Command not found
  - iocshCmd and iocshRun - Only execute EPICS commands, not shell commands
  Environment:
  - EPICS Base: R7.0.5
  - OS: Red Hat Enterprise Linux 8.10
  - IOC built from Galil motor driver (Galil-3-0/3-6)
  Questions:
  1. Is there a way to execute shell commands from within st.cmd in EPICS 7.0.5?
  2. Is system() command availability dependent on build configuration or compile-time options?
  3. Are there alternative approaches to run external scripts during IOC initialization?
  4. Is there a better approach to handle motor position restoration after controller power cycle?
  Current workaround:
  Running python3 generate_restore.py && ./st.cmd manually before each IOC start, but I'd prefer an automated solution.
  Any suggestions would be greatly appreciated!
Alex
RE: power off/on ioc recovery Pearson, Matthew via Tech-talk
power off/on ioc recovery Tran, Phi Dung via Tech-talk
Prev: RE: power off/on ioc recovery Pearson, Matthew via Tech-talk
Next: RE: power off/on ioc recovery Pearson, Matthew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
