Hi Feng, I have implemented a partial stream device support for this once, see attached, but mostly for fixed length fields, as it seems. I hope this helps. Best, Laurenz Am 06.01.2026 um 07:47 schrieb LONG
FENG via Tech-talk:
-- Prof. Dr. Laurenz Rettig Fritz Haber Institute of the Max Planck Society Department of Physical Chemistry Dynamics of Correlated Materials Faradayweg 4-6 14195 Berlin, Germany phone: +49-(0)30-8413 5225 email: rettig at fhi-berlin.mpg.de ########################################################################## # This is an example and debug protocol file for StreamDevice. # # (C) 2010 Dirk Zimoch (dirk.zimoch at psi.ch) # # This file is part of StreamDevice. # # StreamDevice is free software: You can redistribute it and/or modify # it under the terms of the GNU Lesser General Public License as published # by the Free Software Foundation, either version 3 of the License, or # (at your option) any later version. # # StreamDevice is distributed in the hope that it will be useful, # but WITHOUT ANY WARRANTY; without even the implied warranty of # MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the # GNU Lesser General Public License for more details. # # You should have received a copy of the GNU Lesser General Public License # along with StreamDevice. If not, see https://www.gnu.org/licenses/. #########################################################################/ #terminator = CR LF; Terminator = ; #OutTerminator = CR LF; #InTerminator = CR LF; SYNC = "!"; get_rate1 { LEN = 0x24; CMD = "L1"; CRC1 = 0x66; CRC2 = 0x32; out $SYNC, $LEN, $CMD, $CRC1, $CRC2; in $SYNC, "\?A", "% f", " \?\?"; } get_thickness1 { LEN = 0x24; CMD = "N1"; CRC1 = 0x5D; CRC2 = 0x51; out $SYNC, $LEN, $CMD, $CRC1, $CRC2; in $SYNC, "\?A", "% f", " \?\?"; } get_frequency1 { LEN = 0x24; CMD = "P1"; CRC1 = 0x5A; CRC2 = 0x91; out $SYNC, $LEN, $CMD, $CRC1, $CRC2; in $SYNC, "\?A", "%11f", "\?\?"; } get_shutter { LEN = 0x24; CMD = "U?"; CRC1 = 0x5B; CRC2 = 0x54; out $SYNC, $LEN, $CMD, $CRC1, $CRC2; in $SYNC, "\?A", "%!1d", "\?\?"; } get_filmParameters { LEN = 0x25; CMD = "A1?"; CRC1 = 0x2E; CRC2 = 0x95; out $SYNC, $LEN, $CMD, $CRC1, $CRC2; #in $SYNC, "\?A", "%#s%", , "%(\$1.VAL)f", "*f", "%(\$2.VAL)f", "%*f", "%*f", "%*d". "%*d", "\?\?"; in $SYNC, "\?A", "%#8s %(\$1.VAL)f %(\$2.VAL)d %(\$3.VAL)f %*f %*f %*d %*d\?\?"; } set_zero { LEN = 0x23; CMD = "S"; CRC1 = 0x8E; CRC2 = 0x8F; out $SYNC, $LEN, $CMD, $CRC1, $CRC2; in $SYNC, "\?A", "\?\?"; #LEN = 0x23; CMD = "T"; CRC1 = 0x4F; CRC2 = 0x35; #out $SYNC, $LEN, $CMD, $CRC1, $CRC2; #in $SYNC, "\?A", "\?\?"; } ########################################################################## # This is an example and debug EPICS database for StreamDevice. # # (C) 2010 Dirk Zimoch (dirk.zimoch at psi.ch) # # This file is part of StreamDevice. # # StreamDevice is free software: You can redistribute it and/or modify # it under the terms of the GNU Lesser General Public License as published # by the Free Software Foundation, either version 3 of the License, or # (at your option) any later version. # # StreamDevice is distributed in the hope that it will be useful, # but WITHOUT ANY WARRANTY; without even the implied warranty of # MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the # GNU Lesser General Public License for more details. # # You should have received a copy of the GNU Lesser General Public License # along with StreamDevice. If not, see https://www.gnu.org/licenses/. #########################################################################/ record (ai, "$(NAME):Rate") { field (DTYP, "stream") field (INP, "@$(PTCOLS) get_rate1 $(PORT)") field (EGU, "Ang/s") field (SCAN, "1 second") field (FLNK, "$(NAME):Thickness_") } record (ai, "$(NAME):Thickness_") { field (DTYP, "stream") field (INP, "@$(PTCOLS) get_thickness1 $(PORT)") field (EGU, "Ang") field (SCAN, "Passive") field (FLNK, "$(NAME):Frequency") } record (ai, "$(NAME):Frequency") { field (DTYP, "stream") field (INP, "@$(PTCOLS) get_frequency1 $(PORT)") field (EGU, "Hz") field (SCAN, "Passive") field (FLNK, "$(NAME):Shutter_RBV") } record (ai, "$(NAME):Shutter_RBV") { field (DTYP, "stream") field (INP, "@$(PTCOLS) get_shutter $(PORT)") field (SCAN, "Passive") field (FLNK, "$(NAME):Film") } record (ai, "$(NAME):Density") { field (EGU, "g/cm^3") field (SCAN, "Passive") } record (ai, "$(NAME):ToolingFactor") { field (EGU, "%") field (SCAN, "Passive") } record (ai, "$(NAME):Z-ratio") { #field (EGU, "g/cm^3) field (SCAN, "Passive") } record (stringin, "$(NAME):Film") { field (DTYP, "stream") field (INP, "@$(PTCOLS) get_filmParameters($(NAME):Density, $(NAME):ToolingFactor, $(NAME):Z-ratio) $(PORT)") field (SCAN, "Passive") field (FLNK, "$(NAME):MeanRate") } record (bo, "$(NAME):Zero") { field (DTYP, "stream") field (OUT, "@$(PTCOLS) set_zero $(PORT)") field (FLNK, "$(NAME):ThicknessRawOff") } record (ai, "$(NAME):_starttime") { field (DTYP, "Soft Timestamp") field (TSEL, "$(NAME):Zero.TIME") } record (ai, "$(NAME):_currtime") { field (DTYP, "Soft Timestamp") field (TSEL, "$(NAME):Thickness.TIME") } record (calc, "$(NAME):_K1") { #field (EGU, "Ang") field (INPA, "$(NAME):Density") field (INPB, "$(NAME):Z-ratio") field (INPC, "$(NAME):ToolingFactor") field (CALC, "C/100*1.668E13*2.648/(PI*A*B)") } record (calc, "$(NAME):_K2") { #field (EGU, "Ang") field (CALC, "PI/(6E6+5E4)") } record (ai, "$(NAME):ThicknessRawOff") { field (EGU, "Ang") field (INP, "$(NAME):ThicknessRaw.VAL") field (SCAN, "Passive") } record (calc, "$(NAME):ThicknessRaw") { field (EGU, "Ang") field (PREC, "5") field (INPA, "$(NAME):Frequency") field (INPB, "$(NAME):ThicknessRawOff") field (INPC, "$(NAME):Z-ratio") field (INPD, "$(NAME):_K1 PP MS") field (INPE, "$(NAME):_K2 PP MS") field (CALC, "ATAN(C*TAN(PI-E*A))*D/A") field (FLNK, "$(NAME):Thickness") } record (calc, "$(NAME):Thickness") { field (EGU, "Ang") field (PREC, "5") field (INPA, "$(NAME):ThicknessRaw") field (INPB, "$(NAME):ThicknessRawOff") field (CALC, "A-B") } record (calc, "$(NAME):Runtime") { field (EGU, "s") field (INPA, "$(NAME):_starttime PP MS") field (INPB, "$(NAME):_currtime PP MS") field (CALC, "B-A") } record (calc, "$(NAME):MeanRate") { field (EGU, "Ang/s") field (INPA, "$(NAME):Thickness") field (INPB, "$(NAME):Runtime PP MS") field (CALC, "A/B") field (FLNK, "$(NAME):ThicknessRaw") } Attachment:
smime.p7s
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
