Hi Dirk,
Could "%#.4R" convert the 4-byte value 40 49 99 9A (in hexadecimal, big-endian order, ABCD order) corresponding to 3.15 into 99 9A 40 49 (in CDAB order)?
Gao Zhenhua
> -----原始邮件-----
> 发件人: "Zimoch, Dirk" <dirk.zimoch at psi.ch>
> 发送时间:2026-01-08 16:33:27 (星期四)
> 收件人: "gaozh at ihep.ac.cn" <gaozh at ihep.ac.cn>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
> 主题: Re: The problem of converting floating-point numbers to 4-byte format (in CDAB order) under StreamDevice
> Hi Gao
> As Mark already wrote, better use the dedicated Modbus driver, but for
> completeness here is the answer: Use format "%.4R"
> %R is the "floating point raw" format and can be used with precision .4 or .8
> for float or double. By default it used big endian byte order but if needed that
> can be changed to little endian with "%#.4R".
> https://urldefense.us/v3/__https://paulscherrerinstitute.github.io/StreamDevice/formats.html*rawdouble__;Iw!!G_uCfscf7eWS!cV36sNgDUGyQjAE89zx6iw6ud2MpfQqQzvXGhfc1WVzxHT2U7FPuiUCJ_7h1n6GeyyI72v_6YmJE2yM1eMdh$
> BTW: The Modbus checksum is "%<modbus>".
> https://urldefense.us/v3/__https://paulscherrerinstitute.github.io/StreamDevice/formats.html*chksum__;Iw!!G_uCfscf7eWS!cV36sNgDUGyQjAE89zx6iw6ud2MpfQqQzvXGhfc1WVzxHT2U7FPuiUCJ_7h1n6GeyyI72v_6YmJE25i6oT2W$
> Dirk
> On Wed, 2026-01-07 at 17:53 +0800, 高振华 via Tech-talk wrote:
> > Hi all,
> > I am conducting Modbus RTU communication with a device and need to convert a 32-bit floating-point number into 4 bytes of hexadecimal data and then send it to the device.
> > For example: 3.15 converted to 4 bytes is 40 49 99 9A (in hexadecimal, big-endian order, ABCD order).
> > Using StreamDevice, how should I convert to the CDAB order? (For example, the CDAB order corresponding to 3.15 is 99 9A 40 49).
> > Does StreamDevice have a corresponding conversion symbol?
> > Best regards,
> > Gao Zhenhua
> > BSRF
> > Email:gaozh at ihep.ac.cn
祝好!
高振华
电话:010-88235426
- Re: Re: The problem of converting floating-point numbers to 4-byte format (in CDAB order) under StreamDevice Zimoch, Dirk via Tech-talk
- The problem of converting floating-point numbers to 4-byte format (in CDAB order) under StreamDevice 高振华 via Tech-talk
- Re: The problem of converting floating-point numbers to 4-byte format (in CDAB order) under StreamDevice Zimoch, Dirk via Tech-talk
2025
<2026>
2025
<2026>
