1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Subject: RE: Archiver Appliance stuck on initial sampling
From: Dennis Hilhorst via Tech-talk <tech-talk at aps.anl.gov>
To: Sky Brewer <jaco.brewer at gmail.com>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 9 Jan 2026 15:54:57 +0000
Hi Sky,
Thanks for you quick reply! Most PVs are PVA and CA. They are not submitted with a pva:// prefix, though the archiver does seem to detect they are PVA. I restarted the archiver after clearing out all data again and submitted all PVs which are not from a python softioc. They are all from a single ioc running on the same host as the archiver itself, so the subnet should be okay. I have let it run for a few hours, but it still seems to get stuck. All PVs that “may not exist” and are not in the START state are in the METAINFO_GATHERING state, though the PV’s that are currently in the METAINFO_REQUESTED state report does show 1000 PVs, but I can’t abort from there. They seem to be a rather random assortment of PVs, and I don’t see a very common theme between them besides the values that are in the report: all of them say “false” for Monitoring started, and the other values (When, Remaining, Timer Done, Events so far, storage so far and Internal State and all the MainMeta values) are all N/A, 0 or null (the initial values?).
The repo you posted seems to unreachable from outside your facility maybe? I will try to tune these settings after the weekend to see if they have an effect.
Sincerely,
Dennis Hilhorst
Sent: vrijdag 9 januari 2026 11:49
To: tech-talk at aps.anl.gov; Dennis Hilhorst <dhilhorst at highvolteng.com>
Hi Dennis,
I'm guessing most of the PVs are pvAccess?
You can clear the queue of stuck PVs (I would do that for all the python soft IOC pvs that aren't working) by going to
mgmt interface -> reports -> PV's that may not exist
then clicking abort.
I had a similar problem due to having thousands of PVs which were not on the correct subnet blocking the queue and I ended up adding a feature to https://gitlab.esss.lu.se/ics-software/archiver-appliance/epicsarchiver-mgmt to clear them out.
The report PV's that may not exist  and PV's that are currently in METAINFO_REQUESTED are good for debugging this kind of issue.
You can also tune the queue with the section in the arch.properties:
# We impose a throttle on archive requests that are pending. This is an attempt to conserve resources on the engine and also to control CA search broadcast storms
# What this means is that if you have more that this many invalid PV's (PVs that will never connect) in the archive workflow; the ones later in the queue will never get fulfilled unless the archive request queue is cleaned up.
# See abortNeverConnectedPV for a example of how to do this.
# Use this property to increase this batch size.
# Note that there is a limit on how high this can go. We sample the PV for a minute to determine storage rates etc; if this is set very high (> 10000), there may not be enough time to perform the sampling for the archive workflow.
# org.epics.archiverappliance.mgmt.MgmtRuntimeState.archivePVWorkflowBatchSize = 1000
# For larger archivePVWorkflowBatchSize, you may need a longer time between the workflow state machine ticks.
# Set this to 60 seconds or more if you are using archivePVWorkflowBatchSize's of 5000 or greater.
# The workflow may take a little longer per PV but overall may be much faster.
# org.epics.archiverappliance.mgmt.MgmtRuntimeState.archivePVWorkflowTickSeconds = 10
# Abort PV's in the archive PV workflow after this many minutes if the archiver is not able to connect to the PV.
# The workflow can take a few minutes; so this should be set to a reasonable value (for example, 1 minute would mean that no PV would complete the workflow)
# By default, this is set to a day. So, if the archiver cannot connect to the PV in a day, it will give up and abort.
# To turn this off, set this to -1.
# org.epics.archiverappliance.mgmt.MgmtRuntimeState.abortArchiveRequestInMins = 1440
Hope that helps!
Sky Brewer
Re: Archiver Appliance stuck on initial sampling Ralph Lange via Tech-talk
Re: Archiver Appliance stuck on initial sampling Sky Brewer via Tech-talk
RE: Archiver Appliance stuck on initial sampling Sky Brewer via Tech-talk
Prev: RE: problems with SNL - sevr=minor ca_array_get_callback [...]: Virtual circuit disconnect Žiga Oven via Tech-talk
Next: Re: Archiver Appliance stuck on initial sampling Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Prev: RE: Archiver Appliance stuck on initial sampling Sky Brewer via Tech-talk
