1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Error message of StreamDevice while making it.
From: "Zimoch, Dirk via Tech-talk" <tech-talk at aps.anl.gov>
To: "xinss0017 at gmail.com" <xinss0017 at gmail.com>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Cc: "sxin at bnl.gov" <sxin at bnl.gov>
Date: Wed, 14 Jan 2026 15:29:01 +0000
Can I see your linker command line?
Do you use static linking?
Dirk
On Wed, 2026-01-14 at 10:14 -0500, Peter Sx via Tech-talk wrote:
> Good Morning,
> I got errors while I am install the StreamDevice. Does the asyn verion cause the problem. I am using the asyn R4-46 from github. Thank you!
> Susheng
> /usr/bin/ld: streamApp_registerRecordDeviceDriver.o: in function `_GLOBAL__sub_I_streamApp_registerRecordDeviceDriver':
> /usr/lib/epics_support/StreamDevice/streamApp/O.linux-x86_64/streamApp_registerRecordDeviceDriver.cpp:109: undefined reference to `pvar_dset_asynInt16ArrayAai'
> /usr/bin/ld: streamApp_registerRecordDeviceDriver.o: in function `__static_initialization_and_destruction_0':
> /usr/lib/epics_support/StreamDevice/streamApp/O.linux-x86_64/streamApp_registerRecordDeviceDriver.cpp:109: undefined reference to `pvar_dset_asynFloat32ArrayAai'
> /usr/bin/ld: /usr/lib/epics_support/StreamDevice/streamApp/O.linux-x86_64/streamApp_registerRecordDeviceDriver.cpp:109: undefined reference to `pvar_dset_asynInt32ArrayAai'
> /usr/bin/ld: /usr/lib/epics_support/StreamDevice/streamApp/O.linux-x86_64/streamApp_registerRecordDeviceDriver.cpp:109: undefined reference to `pvar_dset_asynFloat64ArrayAai'
> /usr/bin/ld: /usr/lib/epics_support/StreamDevice/streamApp/O.linux-x86_64/streamApp_registerRecordDeviceDriver.cpp:109: undefined reference to `pvar_dset_asynInt64ArrayAai'
> /usr/bin/ld: /usr/lib/epics_support/StreamDevice/streamApp/O.linux-x86_64/streamApp_registerRecordDeviceDriver.cpp:109: undefined reference to `pvar_dset_asynInt8ArrayAao'
> /usr/bin/ld: /usr/lib/epics_support/StreamDevice/streamApp/O.linux-x86_64/streamApp_registerRecordDeviceDriver.cpp:109: undefined reference to `pvar_dset_asynInt16ArrayAao'
> /usr/bin/ld: /usr/lib/epics_support/StreamDevice/streamApp/O.linux-x86_64/streamApp_registerRecordDeviceDriver.cpp:109: undefined reference to `pvar_dset_asynFloat32ArrayAao'
> /usr/bin/ld: /usr/lib/epics_support/StreamDevice/streamApp/O.linux-x86_64/streamApp_registerRecordDeviceDriver.cpp:109: undefined reference to `pvar_dset_asynInt32ArrayAao'
> /usr/bin/ld: /usr/lib/epics_support/StreamDevice/streamApp/O.linux-x86_64/streamApp_registerRecordDeviceDriver.cpp:109: undefined reference to `pvar_dset_asynFloat64ArrayAao'
> /usr/bin/ld: /usr/lib/epics_support/StreamDevice/streamApp/O.linux-x86_64/streamApp_registerRecordDeviceDriver.cpp:109: undefined reference to `pvar_dset_asynInt64ArrayAao'
> /usr/bin/ld: /usr/lib/epics_support/StreamDevice/streamApp/O.linux-x86_64/streamApp_registerRecordDeviceDriver.cpp:320: undefined reference to `pvar_dset_asynInt8ArrayAai'
> collect2: error: ld returned 1 exit status
> make[2]: *** [/usr/lib/epics//configure/RULES_BUILD:227: streamApp] Error 1
> make[2]: Leaving directory '/usr/lib/epics_support/StreamDevice/streamApp/O.linux-x86_64'
> make[1]: *** [/usr/lib/epics//configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
> make[1]: Leaving directory '/usr/lib/epics_support/StreamDevice/streamApp'
> make: *** [/usr/lib/epics//configure/RULES_DIRS:85: streamApp.install] Error 2
Error message of StreamDevice while making it. Peter Sx via Tech-talk
Prev: Error message of StreamDevice while making it. Peter Sx via Tech-talk
Next: Re: Error message of StreamDevice while making it. Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
