1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: IOC does not pool network link PVs?
From: "Johnson, Andrew N. via Tech-talk" <tech-talk at aps.anl.gov>
To: Ralph Lange <ralph.lange at gmx.de>, EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Sun, 18 Jan 2026 14:44:21 +0000
  • Codeathon?
Hmm, some documentation on the non-JSON link types may be in the old AppDevGuide chapters and/or in the “Fields common to all record types” dbd.pod file. Wherever it is it’s worth looking at and expanding, along with the links.dbd.pod file. Good idea.
- Andrew
__
Intelligence isn’t measured by what you know, but by what you do when you don't know. Learning begins when you’re confused; when you reach the edge of your knowledge and plunge into new territory, taking your brain to a place it’s never been before.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
Sent: Sunday, January 18, 2026 5:41:44 AM
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
On Fri, 16 Jan 2026 at 18:51, Kasemir, Kay via Tech-talk <tech-talk at aps.anl.gov> wrote:
As a workaround, you may update your database to insert a ‘mirror’ record like this:
Correct. Using proxy records on the receiving IOC is best practice in such a setup.
Deserves mentioning in the documentation, probably.
Codeathon?
Cheers,
~Ralph
IOC does not pool network link PVs? Kasemir, Kay via Tech-talk
Re: IOC does not pool network link PVs? Ralph Lange via Tech-talk
Prev: Re: IOC does not pool network link PVs? Ralph Lange via Tech-talk
Next: Issues with PVXS Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
