Hi Mark,
On 1/19/26 3:18 PM, Mark Rivers via
Tech-talk wrote:
Hi Ralph,
I'm sure you are correct. I believe the issue is that PVXS is
promoting the datatype during an assignment in the plugin code.
This is not obvious.
This is the line that sets the codec.parameters field in
ntndArrayConverterPvxs.cpp:
m_value["codec.parameters"] = (int32_t)
NDDataTypeToScalar[src->dataType];
m_value is of type pvxs::Value. It is doing its best to define
codec.parameters as being of type int32_t.
However, as far as I can tell PXVS use the StoreType enum to
define the datatypes that can be stored.
StoreType is relevant for the in-memory representation, and does
store scalar integers as (u)int64. (wasting up to 7 bytes!) The
wire representation is determined by the TypeCode
enum, which includes the full range of PVA supported scalar
integer types. As does the in-memory representation for arrays
(see also the ArrayType
enum).
StoreType and ArrayType mostly do not cross over. The exception
is when assigning a variant union (aka ANY). Which is how
"codec.parameters" is defined. Using the "Value::operator=()"
will automatically promote integers, as you have found. Arrays
are not promoted.
PVXS does provide a way to assign an ANY with an explicit type.
Value paramval =
TypeDef(TypeCode::Int32).create();
paramval = NDDataTypeToScalar[src->dataType];
m_value["codec.parameters"].from(paramval);
To make this slightly more efficient, avoid re-creating the type
each time. (TypeDef is relatively expensive)
// once
this->paramval = TypeDef(TypeCode::Int32).create();
// each time
Value paramval(this->paramval.cloneEmpty());
So the issue is that PVXS is not allowing the creation of the
same data structures that PVA does, at least not with the Value
class.
PVXS supports the full range of scalar integer field types.
There is a further issue. NTNDArrays can be compressed. For
compressed arrays the datatype is effectively uint8_t, but the
actual datatype of the original array must be conveyed. By
convention this is stored in codec.parameters as an int. The
int is one of the values in the ScalarType enum.
I completely agree with Ralph that robust client code
interpreting PVA structures should be written to implicitly
convert between numeric types when accessing scalar fields.
pvDataCPP/Java made it complex for API users to do this, leading
to breakages like you are seeing. PVXS makes it complex for users
not to do this. (I can't speak directly for Kay's core.pva
library, but I suspect the same is true)
The ScalarType enum is defined here in
PVA:
For Java it is defined here:
However, I cannot find an equivalent enum in PVXS. So
ntndArrayConverterPvxs.cpp currently has to include
pv/pvIntrospect.h from PVA to get the required definition. This
is ugly since it is mixing code from PVA and PVXS.
In PVXS, the ScalarType enum, along with its cousins, are
collapsed down into the single TypeCode
enum.
https
://github.com/epics-base/pvxs/blob/48b260d008bd1d65c5f132c54523e27b41d0f4c3/src/pvxs/data.h#L154-L190
