1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: How to home translation stage with no encoder/home-switches using motorOmsAsyn
From: Marvin Noll via Tech-talk <tech-talk at aps.anl.gov>
To: <tech-talk at aps.anl.gov>
Date: Thu, 22 Jan 2026 16:35:12 +0100
Dear all,
we are using OMS MAXnet controllers with the motorOmsAsyn ioc.
The stepper motors move translation states, which are only equipped with limit switches at the end (so no encoders or home-switches).
What is the intended procedure to home the stage in this case?
I would expect something like:
1) Stage is at some unknown position
2) Do HomeR
3) Stage moves into lower limit switch
4) VAL/DVAL/RVAL report some value
5) Reset VAL or DVAL or RVAL to 0 (without moving the motor of course)
Many thanks in advance
Marvin
Prev: ZIP_PER_PV compression mode in EAA Shankar, Murali via Tech-talk
Next: p4p timeout on get() in broadcastless network Ulrik Pedersen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
