1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: pvlist does not find all servers in network
From: Florian Feldbauer via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Tue, 27 Jan 2026 13:07:40 +0100
Small addendum:
I stopped the IOC on the crate controller and opened a UDP socket in python listening on port 5076 and afterwards running `pvlist` on the PC again:
>>> import socket
>>> sock = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
>>> sock.bind(("", 5076))
>>> data, addr = sock.recvfrom(1024)
>>> print( data, addr )
b'\xca\x02\x00\x03\x1d\x00\x00\x00\x00\x00\x00\x00\x81\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\xff\xff\x00\x00\x00\x004\xb4\x00\x00\x00' ('192.168.10.53', 46132)
So, the python socket receives the UDP broadcast from the PC.
Therefore I guess there is an issue with the IOC....is there any way of debugging the PVAserver?
Cheers,
Florian
On 1/27/26 13:02, Florian Feldbauer via Tech-talk wrote:
Hey all,
I have a strange problem, that I haven't encountered before.
In our lab we have a small test setup for our pixel sensors.
As HV/LV power supply for these sensors we use a Wiener MPOD crate with an iseg Crate Controller. The crate controller is running Linux (The Ångström Distribution v2017.12) and an EPICS IOC with PVA.
Now, when I run `pvlist` from another PC I see a list of all the IOCs running in this network except the one on the iseg Crate Controller. When I explicitly run `pvlist iseg-iCS2-5230317` I get a list of all PVs from that IOC, so PVA communication works in general, but for some reason this IOC is not reacting on broadcasts.
I checked with netstat and for me this looks correct:
root@iseg-iCS2-5230317:~# netstat -tuln | grep 5076
udp        0      0 224.0.0.128:5076        0.0.0.0:*
udp        0      0 192.168.10.255:5076     0.0.0.0:*
udp        0      0 192.168.10.22:5076      0.0.0.0:*
udp        0      0 :::50767                :::*
There is no firewall running on the crate controller.
Any idea what could cause this issue?
Cheers,
Florian
Ruhr-Universität Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://urldefense.us/v3/__https://paluma.ruhr-uni-bochum.de__;!!G_uCfscf7eWS!eAlEHtUWCZJvqh0MdMlWLNelu_578EdoiL0bVpp3pAtKrw517RqWLAFLri5fzp8vcbhOxzjWYz7zb4EZTd_3G5cEeAadl18JPeA$
Re: pvlist does not find all servers in network Johnson, Andrew N. via Tech-talk
pvlist does not find all servers in network Florian Feldbauer via Tech-talk
Prev: pvlist does not find all servers in network Florian Feldbauer via Tech-talk
Next: Re: pvlist does not find all servers in network Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
