1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: pvlist does not find all servers in network
From: Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov>
To: Florian Feldbauer <florian at ep1.ruhr-uni-bochum.de>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 27 Jan 2026 17:40:09 -0800
Hello Florian,
First, the usual questions.  Which versions of epics-base and associated modules are involved?  Including pvDataCPP, pvAccessCPP, and pva2pva if built as separate modules.  Do you set any of the EPICS_PVA* environment variables?
On this MPOD crate.  Is there only the one IOC process?  fyi. you can add '-p' to 'netstat' and it will tell you which PID each socket is associated with.
As Andrew mentioned.  Setting $EPICS_PVA_DEBUG=3 will turn on a fire hose for logging.
From the output provided, PVXS is not present.  You might also try "pvxlist" and/or "softIocPVX" to see if the behavior differs.
On 1/27/26 4:02 AM, Florian Feldbauer via Tech-talk wrote:
Hey all,
I have a strange problem, that I haven't encountered before.
In our lab we have a small test setup for our pixel sensors.
As HV/LV power supply for these sensors we use a Wiener MPOD crate with an iseg Crate Controller.
The crate controller is running Linux (The Ångström Distribution v2017.12) and an EPICS IOC with PVA.
Now, when I run `pvlist` from another PC I see a list of all the IOCs running in this network except the one on the iseg Crate Controller.
When I explicitly run `pvlist iseg-iCS2-5230317` I get a list of all PVs from that IOC, so PVA communication works in general, but for some reason this IOC is not reacting on broadcasts.
I checked with netstat and for me this looks correct:
root@iseg-iCS2-5230317:~# netstat -tuln | grep 5076
udp        0      0 224.0.0.128:5076        0.0.0.0:*
udp        0      0 192.168.10.255:5076     0.0.0.0:*
udp        0      0 192.168.10.22:5076      0.0.0.0:*
udp        0      0 :::50767                :::*
There is no firewall running on the crate controller.
Any idea what could cause this issue?
Cheers,
Florian
Re: pvlist does not find all servers in network Florian Feldbauer via Tech-talk
Prev: Re: pvlist does not find all servers in network Johnson, Andrew N. via Tech-talk
Next: Re: pvlist does not find all servers in network Florian Feldbauer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
