1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: CAS: Client accept error: Too many open files
From: Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Fri, 30 Jan 2026 20:31:44 +0100
Hi Yong,
On Fri, 30 Jan 2026 at 17:40, Hu, Yong via Tech-talk <tech-talk at aps.anl.gov> wrote:
Hi all,
I recently encountered an issue with a misbehaving Linux softIOC that caused Phoebus / CS-Studio to appear broken when opening certain OPIs.
Symptoms: The IOC was periodically logging the following error: CAS: Client accept error: Too many open files.
That sounds like a Linux host with too-low settings for the limits on open file descriptors per process and/or per user.
Whenever I opened an OPI containing PVs from that IOC, all CSS OPI screens turned pink, and all PVs appeared disconnected. However:
  • caget and camonitor returned correct PV values.
  • The CSS "Probe" tool also displayed PV values normally.
In such low-resource situations, an IOC will start arbitrarily rejecting new client connections (printing the error message you were showing) and accepting other new connections, while existing connections usually continue to work.
Troubleshooting: I traced the problematic IOC (xxx.x.xxx.xxx:38841) based on terminal output during the failure. The logs included the following error:
SEVERE [Thread 55] com.cosylab.epics.caj.CAJContext (getTransport) - Failed to create transport for: /xxx.x.xxx.xxx:38841
com.cosylab.epics.caj.impl.ConnectionException: Failed to connect to '/xxx.x.xxx.xxx:38841'.
    at com.cosylab.epics.caj.impl.CAConnector.connect(CAConnector.java:138)
    at com.cosylab.epics.caj.CAJContext.getTransport(CAJContext.java:1559)
That's the client side when the IOC rejects a new connection. Looks consistent.
Rebooting the IOC resolved the issue — at least temporarily.
Also consistent with low resource limits on the IOC host.
Use netstat, lsof and friends on the IOC hosts to check the file descriptor/TCP connection usage situation. The iocStats also shows FD usage.
Looking for Insight: A Google search didn’t yield much, so I asked ChatGPT, which suggested that a shared CA context might lead to a shared failure. That seems plausible, but I’d appreciate input from anyone familiar with Phoebus or CSS internals. Why would OPI screens appear completely broken while the "Probe" tool continues to retrieve PV values correctly?
My guess: inside Phoebus, Probe is a different client than the Display Builder runtime. One gets their connection accepted, the other rejected.
Cheers,
~Ralph
CAS: Client accept error: Too many open files Hu, Yong via Tech-talk
Prev: Stupid question of the day Graeme Winter via Tech-talk
Next: Re: Stupid question of the day Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: CAS: Client accept error: Too many open files Hu, Yong via Tech-talk
Next: Stupid question of the day Graeme Winter via Tech-talk
