1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: How to use the RVEL field of the motor record
From: "Mathis, Stefan via Tech-talk" <tech-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, Torsten Bögershausen <torsten.bogershausen at ess.eu>, "Zimoch, Dirk" <dirk.zimoch at psi.ch>
Date: Thu, 12 Feb 2026 08:44:57 +0000
Dear Mark,
I found the issue and fixed it. The corresponding PR can be found here: https://github.com/epics-modules/motor/pull/236
@Torsten Bögershausen, @Zimoch, Dirk: Might be interesting for you as well.
Best regards
Stefan
__________________________________________
Paul Scherrer Institut
Dr. Stefan Mathis
WHGA/022
Forschungsstrasse 111
5232 Villigen PSI
Schweiz
Telefon: +41563102926
E-Mail: stefan.mathis at psi.ch
Sent: Wednesday, February 11, 2026 9:18 PM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>; Mathis, Stefan <stefan.mathis at psi.ch>
Hi Mathis,
I have not found any drivers that set the actual velocity.  However, I believe the infrastructure to do so is implemented in asynMotorController.  In you axis poll() method you just need to add this line:
setDoubleParam(pC_->motorVelocity_, actualVelocity);
Please let me know if there are problems with this.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Mathis, Stefan via Tech-talk <tech-talk at aps.anl.gov>
Sent: Wednesday, February 11, 2026 1:27 AM
Subject: How to use the RVEL field of the motor record
Dear all,
I have a asynMotor-based driver (controller inherits from asynMotorController and axis inherits from asynMotorAxis). I would like to populate the RVEL field with the actual velocity read from the hardware, but can't get it to work.
From looking through the source code of the motor record, it seems that the param-lib entry with the index motorVelocity_  is involved into populating RVEL. However, just writing to this param-lib entry and then running callParamCallbacks() does not seem to be sufficient. Are there any other param-lib entries which influence this?
Is there any asynMotor-based example where the RVEL field is actually used?
Thank you very much
Stefan
Dr. Stefan Mathis
WHGA/022
5232 Villigen PSI
Schweiz
Re: How to use the RVEL field of the motor record Peterson, Kevin M. via Tech-talk
How to use the RVEL field of the motor record Mathis, Stefan via Tech-talk
Re: How to use the RVEL field of the motor record Mark Rivers via Tech-talk
Prev: Re: How to use the RVEL field of the motor record Mathis, Stefan via Tech-talk
Next: Re: How to use the RVEL field of the motor record Torsten Bögershausen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: How to use the RVEL field of the motor record Torsten Bögershausen via Tech-talk
Next: Re: How to use the RVEL field of the motor record Peterson, Kevin M. via Tech-talk
