1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Does every DB record need to produce a PV?
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, David Bracey <dbracey at fnal.gov>
Date: Tue, 17 Feb 2026 16:54:49 +0000
Hi Dave,
  • A naïve user of EPICS would think that every database record of every IOC gets exposed as a PV.
Note that there is not a 1:1 relationship between records and PVs.  Even simple records like "bi" expose many record fields as PVs, not just the .VAL field.  For example, the .SCAN, .ZNAM, .ONAM, .SDIS, .DESC, and many more.  More complex records like the "motor" record have dozens of PVs, like .VELO, .ACCL, .STOP, .DVAL, .RVAL, etc.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of David Bracey via Tech-talk <tech-talk at aps.anl.gov>
Sent: Monday, February 16, 2026 10:15 AM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: Does every DB record need to produce a PV?
Is this truly the case?  If so, has any mechanism for hiding the “internal” records ever been discussed?
The PV-space of an EPICS deployment seems very crowded.
Dave Bracey
AD Controls
Fermi National Accelerator Laboratory
Re: Does every DB record need to produce a PV? Sukhanov, Andrei via Tech-talk
Does every DB record need to produce a PV? David Bracey via Tech-talk
Prev: Re: ADPilatus hangs after data collection completes Mark Rivers via Tech-talk
Next: Re: Does every DB record need to produce a PV? Sukhanov, Andrei via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: Does every DB record need to produce a PV? bob dalesio via Tech-talk
