1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Motor control IOC: Delta Tau GeoBrick register (Y:) access from EPICS
From: "Ha, Kiman via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Sat, 28 Feb 2026 23:29:34 +0000
Hello all,
I’m working with a Delta Tau GeoBrick (Turbo PMAC2 family) controlled by an EPICS IOC using a motor record with DTYP=asynMotor.
My purpose is to sniff/verify the EIB1512 EnDat2 encoder protocol for a PandABox interface, so I’d like to read the encoder input raw EnDat2 register words directly from the controller, for example:
• Y:$78B20 (EnDat Data A, Ch1)
• Y:$78B21 (EnDat Data B, Ch1)
• Y:$78B24 (EnDat Data A, Ch2)
• Y:$78B25 (EnDat Data B, Ch2)
From the motor record I see:
• XF:23ID2-OP{Mono-Ax}Mtr.DTYP = asynMotor
• XF:23ID2-OP{Mono-Ax}Mtr.OUT = @asyn(motor,2)
Any suggestions on the recommended way to read these Y: registers as raw words from the IOC (e.g., via an asynOctet port/asynRecord, or a standard PMAC/GeoBrick register PV template).
Kiman
RE: Motor control IOC: Delta Tau GeoBrick register (Y:) access from EPICS Mercado, Ronaldo (DLSLtd, RAL, TEC) via Tech-talk
Prev: Re: the least EPICS_CA_MAX_ARRAY used for EIGER2 4M detector Mark Rivers via Tech-talk
Next: AreaDetector Collaboration Meeting - March 5th Érico Nogueira Rolim via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: Re: the least EPICS_CA_MAX_ARRAY used for EIGER2 4M detector Zhibang Shen via Tech-talk
Next: RE: Motor control IOC: Delta Tau GeoBrick register (Y:) access from EPICS Mercado, Ronaldo (DLSLtd, RAL, TEC) via Tech-talk
