1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: motor R7-4 released
From: "Peterson, Kevin M. via Tech-talk" <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Mon, 9 Mar 2026 20:54:40 +0000
Release 7-4 of the motor module is now available.
The release notes can be found on github:
   https://urldefense.us/v3/__https://gcc02.safelinks.protection.outlook.com/?url=https*3A*2F*2Fgithub.com*2Fepics-modules*2Fmotor*2Freleases*2Ftag*2FR7-4&data=05*7C02*7Ctech-talk*40aps.anl.gov*7C816470cdf5794d50890808de7e1e159d*7C0cfca18525f749e38ae7704d5326e285*7C0*7C0*7C639086864820718214*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=7Dt55DAJips*2BPVNWUQST9FqbNJaDADPSLw3Msa16VxM*3D&reserved=0__;JSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSU!!G_uCfscf7eWS!d39h2KEsyI58uX_q7C2s87wcSqvLpu_jWwK2q6EdCbHAboqhi_ZcEXZUNJ9QrDJx1e6UHrjXG04kcy9n7auIm9I$
R7-4 includes updated versions of many of the driver submodules.
The source code on the release page contains only the source code from the motor module.  The motor-7-4 archives contain the source code from the motor module as well as all of the driver submodules.
It is likely there will be a R7-4-1 bugfix release as minor issues are found in this release.  This will be the last motor release that supports EPICS base 3.15.
The next significant release of motor will be R8-0, which will almost certainly only work with EPICS base 7.0 or later.  The plan is for R8-0 to finally support 64-bit raw positions in the motor record, thus eliminating the need to resort to workarounds using the RDBL field.
Kevin
Prev: RE: EPICS Collaboration Meeting Spring 2026 - CEA IRFU Paris-Saclay GOUGNAUD Francoise via Tech-talk
Next: Re: CA gateway crashes periodically due to badly behaved servers Williams Jr., Ernest L. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: Latest ADPilatus version for camserver 7.3.13 Henrique F. Simoes via Tech-talk
Next: CAMAC Bob Dalesio via Tech-talk
