On 3/11/26 9:19 AM, Priller, John via
Tech-talk wrote:
Susheng;
What version of libsnmp do you have installed?
Also check build options. It looks
like DES support is now a compile time option.
$ grep -RB1
NETSNMP_DISABLE_DES /usr/include/net-snmp/
/usr/include/net-snmp/net-snmp-config.h-/*
Define if DES encryption should not be supported */
/usr/include/net-snmp/net-snmp-config.h:/*
#undef NETSNMP_DISABLE_DES */
This is what version I'm compiling against, shown with
the net-snmp-config command, on this Linux version I got
from uname:
$> net-snmp-config --version
5.9.4.pre2
uname -v
uname -v
#1 SMP PREEMPT_DYNAMIC Debian 6.12.27-1 (2025-05-06)
I tried compiling on a host with a slightly older version
of debian, which also compiles okay:
>$ net-snmp-config --version
#1 SMP Debian 4.19.316-1 (2024-06-25)
[EXTERNAL] This email originated from outside of FRIB
Dear John and EPICS specialist,
I have the following errors while compiling the
SNMP 1.1.0.5. Could you please help me out? My EPICS
version is V7.0.9. Thank you!
Susheng
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE
-DdevSnmp_NETSNMP_VERSION=50901 -D_X86_64_ -DUNIX
-Dlinux -O3 -g -Wall -DUSE_TYPED_RSET
-mtune=generic -m64 -fPIC -I. -I../O.Common -I.
-I. -I.. -I../../../include/compiler/gcc
-I../../../include/os/Linux -I../../../include
-I/usr/local/epics/base//include/compiler/gcc
-I/usr/local/epics/base//include/os/Linux
-I/usr/local/epics/base//include -c
../devSnmp.cpp
../devSnmp.cpp: In member function ‘void
devSnmp_host::setSnmpV3Param(const char*, const char*,
bool)’:
../devSnmp.cpp:3299:60: error: ‘usmDESPrivProtocol’ was
not declared in this scope; did you mean
‘usmAESPrivProtocol’?
3299 | v3params.securityPrivProto =
snmp_duplicate_objid(usmDESPrivProtocol,USM_PRIV_PROTO_DES_LEN);
usmAESPrivProtocol
make[3]: ***
[/usr/local/epics/base//configure/RULES_BUILD:268:
devSnmp.o] Error 1
make[3]: Leaving directory
'/home/sxin/Downloads/epics-snmp-1.1.0.5/snmpApp/src/O.linux-x86_64'
make[2]: ***
[/usr/local/epics/base//configure/RULES_ARCHS:58:
install.linux-x86_64] Error 2
make[2]: Leaving directory
'/home/sxin/Downloads/epics-snmp-1.1.0.5/snmpApp/src'
make[1]: ***
[/usr/local/epics/base//configure/RULES_DIRS:85:
src.install] Error 2
make[1]: Leaving directory
'/home/sxin/Downloads/epics-snmp-1.1.0.5/snmpApp'
make: ***
snmpApp.install] Error 2
- EPICS SNMP compile error Peter Sx via Tech-talk
- Re: EPICS SNMP compile error Priller, John via Tech-talk
Re: pvget, pvxget and pvxs interoperability and differences Michael Davidsaver via Tech-talk
2025
<2026>
Re: EPICS SNMP compile error Peter Sx via Tech-talk
2025
<2026>
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
