1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Subject: Re: Problem reading SNMP Gauge32 values with devSnmp AI/LI records
From: "Priller, John via Tech-talk" <tech-talk at aps.anl.gov>
To: Varuna Crishan Meddage <vmeddage at fnal.gov>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 13 Mar 2026 21:46:34 +0000
Varuna;
Is this an integer value you're trying to read?  In that case I'd suggest a longin record type using this for your INP field:
field(INP, "@$(HOST) $(COMMUNITY) $(W)::nsFaultSatView1.$(id) Gauge: 100 i")
Here "Gauge:" is the mask for what to strip away and the integer value is what's left after it.
The 'i' is optional for an input field, but would be needed if you wanted to read the value in a native integer format by adding the 'n' flag.  That's what this INP below does, instead of the above example which reads the value as a string and then converts to an integer.
field(INP, "@$(HOST) $(COMMUNITY) $(W)::nsFaultSatView1.$(id) Gauge: 100 in")
This saves a miniscule amount of processing time by skipping the string-to-int conversion.  The native flag is usually used with floats, to achieve better precision.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Varuna Crishan Meddage via Tech-talk <tech-talk at aps.anl.gov>
Sent: Friday, March 13, 2026 5:13 PM
To: tech-talk at aps.anl.gov
Subject: Problem reading SNMP Gauge32 values with devSnmp AI/LI records
[EXTERNAL] This email originated from outside of FRIB
Hi all,
I am trying to read SNMP Gauge32 variables from a Novus GPS device using the devSnmp EPICS driver.
Here’s my setup:
-  community: novus
- SNMP variable: NOVUS-SECURE-MIB::nsFaultSatView1.0 (Gauge32)
- Record type: stringin / ai / longin (tried multiple)
- Template snippet:
record(stringin, "$(acc):$(sys)_$(group):nsFaultSatView1")
  field(DTYP, "Snmp")
  field(INP, "@$(HOST) $(COMMUNITY) $(W)::nsFaultSatView1.$(id) 1 100 s")
  field(SCAN, "10 second")
When I start the IOC, I get:
2026/03/13 15:31:50 devSnmp SI read error '<PREFIX>:nsFaultSatView1' : mask '0' not found in 'Gauge32: 14'
I have tried:
- Using `mask = 0`, `1`, `-1`, `0xffffffff`, `*`
- Switching to `ai` or `longin` record types
- Using `:raw` in the OID
- Reading via `stringin` + calc record
All attempts fail with the "mask not found" error.
Question
Is there a way to read **Gauge32 numeric SNMP variables** using  devSnmp?
Any guidance would be appreciated!
Varuna
Re: Problem reading SNMP Gauge32 values with devSnmp AI/LI records Priller, John via Tech-talk
Problem reading SNMP Gauge32 values with devSnmp AI/LI records Varuna Crishan Meddage via Tech-talk
Prev: Re: [Ext]Re: Scaler/MCS dark counts? Mark Rivers via Tech-talk
Next: Re: Problem reading SNMP Gauge32 values with devSnmp AI/LI records Priller, John via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Prev: Problem reading SNMP Gauge32 values with devSnmp AI/LI records Varuna Crishan Meddage via Tech-talk
