1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: MRES and friends
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>, "Siddons, David" <siddons at bnl.gov>
Date: Sun, 15 Mar 2026 18:00:54 +0000
Hi Pete,
I think you mean SREV and UREV, not SRES and URES.
MRES is user-units per step
SREV is steps/revolution
UREV is user-units per revolution
MRES = UREV/SREV
Many users find SREV and UREV more descriptive of the drive train, and so we use these in the template file.
For example if I am using a conventional 2-phase stepper motor with 16x micro-stepping, and a 2 mm pitch lead screw then I use:
SREV = 200*16 = 3200
UREV = 2.0
I find this more intuitive and easier to understand than
MRES = 0.000625
It doesn't really go to me directly, it is just that Outlook has associated tech-talk.aps.anl.gov with my name.  That happens to me for other users as well from time to time.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Siddons, David via Tech-talk <tech-talk at aps.anl.gov>
Sent: Sunday, March 15, 2026 10:13 AM
Subject: MRES and friends
This question is not specifically for Mark, but Outlook insists it go to him, don't know why.
I am confused by the MRES/SRES/URES trio in the motor record.
MRES is obvious, and for me this seems to be the only one of the three needed, and should be in EGU/step. What are the use cases that need the other two? OK, if the drive has microstepping, that changes the steps per resolution as well as the EGU/step, but so what?
Maybe I'm missing some key concept here 🙂
Pete.
Re: MRES and friends Jemian, Peter R via Tech-talk
MRES and friends Siddons, David via Tech-talk
Prev: MRES and friends Siddons, David via Tech-talk
Next: Re: MRES and friends Jemian, Peter R via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
