1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Subject: [ANN] e3 - major architectural update
From: Anders Lindh Olsson via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Wed, 18 Mar 2026 08:49:38 +0000
Hi all,
It is my pleasure and privilege to announce the next generation of e3 (https://e3.pages.ess.eu), the EPICS environment used at ESS.
A major architectural change is that e3 now uses conda as its package and environment manager, modelled on conda-forge. This gives us distro-agnostic deployment, full reproducibility via stored build artifacts, and fully resolved dependencies across build/run/test. It also moves us away from the traditional model of shared installations distributed over NFS. As before, e3 supports isolated environments - meaning multiple IOCs with different module versions, or different EPICS base versions, can coexist on the same host. This, together with distribution agnosticism, allows us to migrate away from the EOL CentOS 7.
Alongside this, we have released require 6.0.0, which sheds a lot of its former complexity now that a proper package manager is in the picture. Notably, module loading is now delegated to the dynamic linker (ld) rather than handled internally. Features that are now the package manager's job - multi-version handling, dependency resolution - have been removed. We have also switched to PVXS as the IOC PVA stack (softIocPVX).
Questions and discussion welcome here or in the "EPICS e3" room on EPICS Chat.
Cheers,
Anders on behalf of the e3 team
Prev: Re: question about pvmonitor behavior Érico Nogueira Rolim via Tech-talk
Next: OPC UA Device Support - Limit in the number of PVs eusebio_naif AL-SOLIMAN FUENTES via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Prev: Re: question about pvmonitor behavior Railton, Irie (STFC,RAL,CLF) via Tech-talk
