1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Handling epicsParseDouble Errors from SNMP PVs Returning Empty or Unexpected Values
From: "Priller, John via Tech-talk" <tech-talk at aps.anl.gov>
To: Varuna Crishan Meddage <vmeddage at fnal.gov>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 18 Mar 2026 16:36:37 +0000
It looks to me like the device is returning "" and the net-snmp library complains this doesn't match what the MIB file declares it should be, an integer value.  Is there perhaps an updated MIB available from the manufacturer?
You could also specify the 'n' native flag in your INP field to avoid parsing strings altogether:
field(INP, "@$(HOST) $(COMMUNITY) $(W)::nsRbDiscStatus.$(id)  ( 100 in")
But I'm not sure what you'd get back.  There's some mismatch between the MIB and the device that needs to be addressed.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Varuna Crishan Meddage via Tech-talk <tech-talk at aps.anl.gov>
Sent: Wednesday, March 18, 2026 12:27 PM
To: tech-talk at aps.anl.gov
Subject: Handling epicsParseDouble Errors from SNMP PVs Returning Empty or Unexpected Values
[EXTERNAL] This email originated from outside of FRIB
I have the following EPICS record defined
record(ai, "$(acc):$(sys)_$(group):nsRbDiscStatus")
  field(SCAN, "10 second")
  field(DTYP, "Snmp")
  field(INP, "@$(HOST) $(COMMUNITY) $(W)::nsRbDiscStatus.$(id)  ( 100 i")
  field(DESC, "Rb Discipline Status")
  #field(HIGH,"2")
  #field(HIHI,"3")
  #field(LOW,"0")
  #field(LOLO,"-1")
  #field(LLSV, MAJOR)
  #field(LSV, MINOR)
  #field(HSV, MINOR)
  #field(HHSV, MAJOR)
For this EPICs record I get the following error during runtime.
devSnmp AI read error 'PIP2:TIME_CTRL_GPS:nsRbDiscStatus' : epicsParseDouble failed on 'should be INTEGER): ""'
In the MIB file this variable is defined as follows
nsRbDiscStatus OBJECT-TYPE
    SYNTAX      INTEGER { disciplinewait(0),disciplinegood(1),holdover(2) }
    MAX-ACCESS  read-only
    STATUS      current
    DESCRIPTION
        "Rb Discipline Status: 0=Disc Wait, 1=Disc Good, 2=Holdover"
    ::= { nsRubidiumObjs 4 }
When I ran the snmpwalk command, the output for this variable is
NOVUS-SECURE-MIB::nsRbDiscStatus.0 = Wrong Type (should be INTEGER): ""
Any suggestions to solve this issue ?
Thanks
Varuna Meddage
Re: Handling epicsParseDouble Errors from SNMP PVs Returning Empty or Unexpected Values Varuna Crishan Meddage via Tech-talk
Prev: Handling epicsParseDouble Errors from SNMP PVs Returning Empty or Unexpected Values Varuna Crishan Meddage via Tech-talk
Next: Re: Handling epicsParseDouble Errors from SNMP PVs Returning Empty or Unexpected Values Varuna Crishan Meddage via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
