1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Subject: Re: Streams question
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk <tech-talk at aps.anl.gov>, Steven Hunt <Hunt at lbl.gov>
Date: Fri, 20 Mar 2026 17:54:37 +0000
Hi Steve,
Have you tried enabling asynTrace and sending it to a file to capture the RS-232 stream?  That can tell you if occasionally the device has a long delay before sending the final <0a>.
Also, are you using a terminal server, or is this a local serial port?  Terminal servers can be configured to do buffering, which might cause this.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Steven Hunt via Tech-talk <tech-talk at aps.anl.gov>
Sent: Friday, March 20, 2026 11:59 AM
Subject: Streams question
Hi we have a device that reads the following data over RS232
"000001 0000F9 0000 0000 0000 0000 0F 00 00<0d><0a>"
The data comes quite slowly, every 4 seconds (@ 9600 baud if I remember correctly)  via a port server , we were using the following proto file (simplified version)
ReadTimeout = 1000;
Terminator = CR LF;
dose_rate {in "%x %*x %*x %*x %*x %*x %*x %*x %*x";}
This has been working well, but occasionally we get last character is missing.
StreamIoSuccess input="000001 00005A 0000 0000 0000 0000 0F 00 00<0d>", size=43)
Then catch it in the next buffer
StreamIoSuccess input="<0a>000001 00005A 0000 0000 0000 0000 0F 00 00<0d><0a>", size=45)
We have tried many combinations of the proto file, changing timeout, ignore extra input etc, putting everything into a long char buffer ,,,,,
Can anyone advise on the best protocol file entry to capture this type of data cleanly?
Steve
Streams question Steven Hunt via Tech-talk
Prev: Streams question Steven Hunt via Tech-talk
Next: Re: Streams question Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
ANJ, 20 Mar 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
