1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Subject: Lack of error message from invalid CROSS_COMPILER_TARGET_ARCHS
From: "Wells, Alex \(DLSLtd,RAL,TEC\) via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 24 Mar 2026 15:14:13 +0000
Hello Tech Talk,
I'm looking for some information as to why there's no obvious error message when specifying a CROSS_COMPILER_TARGET_ARCHS value that is not defined in your EPICS base installation. I would have expected there to be some kind of error message during compilation time, as EPICS obviously cannot compile my application for a platform it knows nothing about.
I do observe that a folder titled "O.<invalid platform>" is created, and populated with a Makefile that has the same format as a valid platform - the only difference is the "T_A=<platform>" parameter is changed to the non-existent one. I do see that the Make process does go into the directory and run the file, but the build system reports "nothing to be done for 'install'".
I ask this as I spent a few hours debugging why my application wasn't building. It turns out our new EPICS base installation was not configured for "linux-arm_elhf" builds.
Thank you for any information,
Alex Wells
This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail. Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd.
Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom.
Re: Lack of error message from invalid CROSS_COMPILER_TARGET_ARCHS Johnson, Andrew N. via Tech-talk
Prev: Re: MAXnet Alarm State Under High Motor Command Load Mrinal Bera via Tech-talk
Next: Re: IR cameras Wang, SuYin Grass via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Prev: Looking for mutex contention in Linux IOCs Michael Davidsaver via Tech-talk
Next: Re: Lack of error message from invalid CROSS_COMPILER_TARGET_ARCHS Johnson, Andrew N. via Tech-talk
ANJ, 24 Mar 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
