1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: epics-rs — A Pure Rust EPICS Implementation for Beamline Simulation
From: "Hu, Yong via Tech-talk" <tech-talk at aps.anl.gov>
To: Sang-Woo Kim <physwkim at postech.ac.kr>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 1 Apr 2026 16:57:22 +0000
Hello SangWoo,
Thank you so much for sharing your epics-rs. I did a quick test on my Apple MacBook. It worked like a charm.
For now, I only have one suggestion: you may mention where is the location of the command "softioc-rs"​ in the section of ​`Quick Start`.  I figured it out by looking .gitignore.
Cheers,
Yong
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Sang-Woo Kim via Tech-talk <tech-talk at aps.anl.gov>
Date: Wednesday, April 1, 2026 at 5:58 AM
Hi all,
I’d like to share a project I’ve been working on: epics-rs, a pure Rust implementation of the EPICS control system framework.
https://github.com/epics-rs/epics-rs
The goal of this project is to provide a simple, self-contained environment for simulating a full beamline—motors, detectors, monochromator, slits, BPM, and more—on a single machine without requiring external dependencies.
A good starting point is the examples/mini-beamline IOC, which brings up a simulated beamline with:
All components are wire-compatible with standard Channel Access clients (e.g., caget, camonitor, CSS), and everything builds with Cargo.
The project is currently organized into multiple crates covering core EPICS functionality, CA protocol, device support, and optics-related components.
This is still an early-stage project, and I would greatly appreciate any feedback or suggestions.
Thank you for your time.
Best regards,
SangWoo Kim
Pohang Accelerator Laboratory (PAL),
80, 127 Beon-gil, Jigok-ro, Namgu, Pohang, 37673, Korea (South).
Tel : +82-54-279-1426
epics-rs — A Pure Rust EPICS Implementation for Beamline Simulation Sang-Woo Kim via Tech-talk
Prev: epics-rs — A Pure Rust EPICS Implementation for Beamline Simulation Sang-Woo Kim via Tech-talk
Next: MKS Granville-Phillips® 475 Convectron® Vacuum Gauge Controller Peterson, Kevin M. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
ANJ, 02 Apr 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
