1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Assistance Required for EPICS Archiver Installation on Ubuntu 22.04 LTS
From: "Wang, Lin via Tech-talk" <tech-talk at aps.anl.gov>
To: Jatin <space.jatin at gmail.com>
Cc: tech-talk at aps.anl.gov
Date: Fri, 17 Apr 2026 18:42:54 +0800 (GMT+08:00)
Hello Jatin,
I assume it is installed using install_scripts/single_machine_install.sh, for beginner, probably the following points can be taken into account,
1. The web page URL should be something like http://the_ip_address:17665/mgmt/ui/index.html
2. tomcat_instances/mgmt/logs/catalina.err can typically track errors when starting up
3. From Archiver Appliance v2.2.0, Tomcat must be version 10 or above
Lin
-----Original Messages-----
From: "Jatin via Tech-talk" <tech-talk at aps.anl.gov>
Send time: Friday, 04/17/2026 12:24:00
To: tech-talk at aps.anl.gov
Subject: Assistance Required for EPICS Archiver Installation on Ubuntu 22.04 LTS
Dear Sir/Madam,
I am trying to install the EPICS Archiver on Ubuntu Linux 22.04 LTS, but I am facing issues accessing it after deployment.
My current setup is as follows:
  • EPICS Base: R7.0.9
  • OpenJDK: 17 (openjdk-17-jdk)
  • Apache Tomcat: 9.0.117
  • Archiver packages used:
    • archappl_v1.1.0.tar.gz
    • archappl_v2.2.1.tar.gz
Despite following the installation steps, I am unable to access the archiver through the web interface. Every time I try to open the webpage, I receive a 404 error.
As I am a beginner with EPICS Archiver, I may be missing some configuration steps or dependencies. I would really appreciate your guidance in resolving this issue and successfully completing the installation.
Kindly help me with the correct procedure or suggest any troubleshooting steps.
Thank you for your time and support.
Best regards,
Jatin Kumar
Assistance Required for EPICS Archiver Installation on Ubuntu 22.04 LTS Jatin via Tech-talk
Prev: Re: Assistance Required for EPICS Archiver Installation on Ubuntu 22.04 LTS Heinz Junkes via Tech-talk
Next: ADS driver 3.2.0 and autoparamDriver 2.1.0 Jure Varlec via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
ANJ, 17 Apr 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
