1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: BO which should switch to 1 whenever processed
From: Majer Karel via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 23 Apr 2026 07:44:46 +0000
Hello,
I would like to have a BO record which sets its value to 1 whenever processed (without necessarily writing 1 to VAL), then back to 0.
It's part of PLC-based motion control IOC. The database should allow moving the motor to saved waypoint positions; it looks like this:
record(ao, "AbsPos") {
    field(EGU,  "step")
record(ao, "Waypoint1") {
    field(EGU,  "step")
record(longout, "WaypointIdx") {
    field(FLNK, "SelectAbsPos")
record(sel, "SelectAbsPos") {
    field(SELM, "Specified")
    field(NVL,  "WaypointIdx")
    field(INPA, "AbsPos")
    field(INPB, "Waypoint1")
    field(FLNK, "DesiredPos")
record(ao, "DesiredPos") {
    field(EGU,  "step")
    # field(OUT,  "OUTLINK")  link to PLC
    field(DOL,  "SelectAbsPos")
    field(OMSL, "closed_loop")
    field(FLNK, "MoveToPos PP")
The processing chain is WaypointIdx -> SelectAbsPos -> DesiredPos -> MoveToPos
MoveToPos is a BO which tells the PLC to start motion, and it must have HIGH field set to non-zero. I'm having a problem triggering its processing in a way that its value becomes 1.
I tried this:
Record(bo, "MoveToPos) {
    field(DOL,  "1")
    field(HIGH, "1)
I expected that processing the record would set VAL to 1, then back to 0 after 1 second. It works only once; subsequent processing does not switch value back to 1. Writing 1 into VAL works as expected. Is this the correct functionality of the BO record?
I ended up with the following construct, which provides the desired functionality, but I don't much like having a record which only holds a constant value to be put into the BO. Is there a better way to do this?
    field(EGU,  "step")
    field(FLNK, "Constant1")
record(longout, "Constant1") {
    field(VAL,  "1")
    field(OUT,  "MoveToPos PP")
record(bo, "MoveToPos") {
    field(HIGH, "1")
Karel
Karel Majer | Senior software developer
Phone: +420 266 051 514
E-mail:
karel.majer at eli-beams.eu
ELI Beamlines Facility|The Extreme Light Infrastructure ERIC
Za Radnicí 835, 252 41 Dolní Břežany, The Czech Republic
www.eli-beams.eu
RE: BO which should switch to 1 whenever processed Pearson, Matthew via Tech-talk
Prev: Re: PVXS and CA Put benchmark Robby Tanner via Tech-talk
Next: Re: Simulate an existing IOC with a python IOC Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: PVXS and CA Put benchmark Michael Davidsaver via Tech-talk
Next: RE: BO which should switch to 1 whenever processed Pearson, Matthew via Tech-talk
ANJ, 11 May 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
