1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Anyone using Zaber motion controllers
From: Érico Nogueira Rolim via Tech-talk <tech-talk at aps.anl.gov>
To: Ralph Lange <ralph.lange at gmx.de>, EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Fri, 24 Apr 2026 17:03:28 +0000
Hi Ralph!
We recently got a Zaber controller here, and I'd also like to avoid depending on the ZML Go stuff.
Do you know if the Diagnostic system folks have developed any kind of driver for the motor? We would be interested in it, if it avoids the complicated dependency.
Cheers,
Érico
On 11/7/25 11:15, Ralph Lange via Tech-talk wrote:
On Fri, 7 Nov 2025 at 13:09, Torsten Bögershausen <tboegi at edom.se> wrote:
Salut,
I read the information from Matt in a completely different way.
Back to the basics. The documentation is pretty good, I think.
   For the binary format, they use 6 bytes for each message:
<https://www.zaber.com/protocolmanualprotocol=Binary#topic_message_format>
I also find the documentation looking pretty good.
Careful: Zaber calls the binary protocol "legacy". [1]
I wouldn't start a new project based on it.
So, what do you really need ?
(Send my a device, and I will implement a driverfor it ;-)
This is for ITER - which means: Personally, I don't need anything. I hardly know how to spell Zaber.
A developer of a Diagnostic system who is considering a Zaber device is asking me how to integrate it best into EPICS, given that - if they decide to use it - it needs to be supported (by us!) for the next ~30 years.
In that context, "requires a current version of Golang" sounds pretty scary, so I was asking the EPICS community what the experiences with Zaber devices are.
Based on the answers so far, I will go with:
"Looks like a reasonable device choice. Use the ASCII protocol. Based on the functionality you need, start with StreamDevice and/or write a type 3 motor support if that fits better. Try to avoid the Motion Library as introducing a new programming language would need strong justification."
Cheers,
~Ralph
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: Anyone using Zaber motion controllers Sukhanov, Andrei via Tech-talk
Prev: Re: CPU usage and response time of EPICS Channel Access responses Johnson, Andrew N. via Tech-talk
Next: Re: Anyone using Zaber motion controllers Sukhanov, Andrei via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
ANJ, 24 Apr 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
