Folks,
This is my environment:
Base 7.0.10
Visual Studio compiler version: Microsoft (R) C/C++ Optimizing Compiler Version 19.44.35215 for x64
sscanRecord version: master branch in the link above.
I tested by deleting all of the xxxRecord.obj files in the O.windows-64 or O.windows-x64-static directories and then timing how long it took "make" to complete. This is the time to both compile the xxxRecord.c files and the time to link the relevant library.
"make" was run without the -j option, so the build was sequential, not parallel.
The following table compares the time to compile and link the relevant library for a number of EPICS records on both static builds (windows-x64-static) and dynamic builds (windows-x64).
Files
Total lines of C code
Time (s) for windows-x64
Time (s) for windows-x64-static
All 34 record files in base/modules/database/src/std/rec
13,369
54
59
All 5 record files in calc/calcApp/src
5,460
30
23
sscanRecord.c
5,596
242
251
This is what I see with Windows TaskManager when compiling sscanRecord.c and linking the library:
This seems very strange to me. It is taking 8-10 times longer to compile and link sscanRecord.c than it does to compile and link essentially the same number of lines of record code for the 5 records in calcApp.
Any ideas?
