1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Televac MM200 questions
From: "James P. Withrow via Tech-talk" <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Sun, 3 May 2026 18:48:05 +0000
Hello all -
I'm in the process of moving instrumentation on our beamline to EPICS-based solutions instead of bespoke hardware/software combinations. I've recently moved the vacuum readouts (Televac MM200) and ion pumps (Digitel MPC) to IOCs using the synApps 'vac' module. This solution works perfectly for both the gauges and the pumps - with the exception of one set of Televac gauges. The set of gauges which works is using firmware rev. 2.13, while the one having issues is on 2.18. The latter set will run normally for 20-30 seconds, and then appear to hang. Once the vac module times out, it attempts to send its next query which confuses the gauge (returns 'R?') but then starts working again.
Has anyone else encountered this issue and are there any possible tuning options for the serial communications?
Thank you in advance,
-Jim
Jim Withrow, Research Support Specialist - jwithrow at cornell.edu
NE-CAT, Cornell University - https://necat.chem.cornell.edu
Advanced Photon Source, Sector 24
9700 S. Cass Avenue, Building 436 E001
Lemont, IL 60439
Re: Televac MM200 questions Smith, Martin via Tech-talk
Prev: Re: PVXS and CA Put benchmark Bernardo Brotas Carvalho via Tech-talk
Next: RE: Strange problem when compiling sscanRecord.c on Windows Freddie Akeroyd - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: Strange problem when compiling sscanRecord.c on Windows Peterson, Kevin M. via Tech-talk
Next: Re: Televac MM200 questions Smith, Martin via Tech-talk
ANJ, 07 May 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
