1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: RE: Understanding alarms, alarm server and notification usage in other facilities
From: "Blomley, Edmund \(IBPT\) via Tech-talk" <tech-talk at aps.anl.gov>
To: Érico Nogueira Rolim <erico.rolim at lnls.br>, "EPICS Tech Talk" <tech-talk at aps.anl.gov>
Date: Mon, 4 May 2026 08:34:24 +0000
Hey Érico,
During the 2026 Spring collaboration meeting I presented a follow-up. You can find the slides here: https://indico.in2p3.fr/event/37441/contributions/171969/
We basically developed a module which reduces the effort for more "dynamic alarms" down to defining additional info fields for the EPICS records itself. You can have a look at the current status of the module: https://github.com/KIT-IBPT/conditional-field-adjuster
It is currently in preview, but I hope we will be able to add some configuration options and release a proper version soon.
This module of course will not (and is not designed to) tackle all the concerns you raised, and modifications still require changes to IOC-related files.
As for notifications via E-Mail/SMS/etc.: We currently use a Python SoftIOC-based approach where independent e-mail alarms can be configured for individual PVs (including throttling options). We can therefore set up e-mail notifications for individual PVs to individual people/e-mail lists. But I wouldn't say that I am particular happy with this system as it adds parallel "alarm infrastructure" (and then there is the more general issue of the whole process and workflow of how to react to e-mail notifications). But adding additional "protocols" such as messengers, MS teams, Matrix, etc. would be relatively easy.
For the future I would probably migrate these notifications to instead create Olog entries and add e-mail notifications to certain types of Olog logbooks. AutOlog ( also presented during the collaboration meeting https://indico.in2p3.fr/event/37441/contributions/172027/ ) might make that easier to do.
But the idea of both approaches is the same: use another software layer and configurations (Python in this case) to generate individual notifications. You can probably also use the Phoebus alarm server in a similar fashion.
Therefore I would also be curious how other facilities approach these issues.
What we will probably end up with are:
- "more flexible" alarms on the EPICS PV layers using the module above
--- some of these "alarms" would rather be classified as notifications and some will not end up in the alarm server
--- some alarms will trigger Olog entries or additional notifications
- some other "states" will also trigger notifications/logbook entries (which might not propagate to the alarm server: developer or engineering info, measurement related info etc.)
But I am always interested in exploring other solutions or discuss the topic of alarms and notifications in more detail.
Cheers
eddy
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Understanding alarms, alarm server and notification usage in other facilities Érico Nogueira Rolim via Tech-talk
Prev: RE: Strange problem when compiling sscanRecord.c on Windows Freddie Akeroyd - STFC UKRI via Tech-talk
Next: Re: Televac MM200 questions Smith, Martin via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Understanding alarms, alarm server and notification usage in other facilities Érico Nogueira Rolim via Tech-talk
Next: Re: Understanding alarms, alarm server and notification usage in other facilities Michael Davidsaver via Tech-talk
ANJ, 11 May 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
