1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Base 7.0.10 and RHEL 6
From: "James P. Withrow via Tech-talk" <tech-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>
Cc: Tech Talk EPICS <tech-talk at aps.anl.gov>
Date: Mon, 4 May 2026 18:07:45 +0000
Mark -
I had run into this in the past when trying to build EPICS on older hardware. I’m in a meeting at the moment but can look once I’m out and see what the solution was.
-Jim
Jim Withrow, Research Support Specialist - jwithrow at cornell.edu
NE-CAT, Cornell University - https://necat.chem.cornell.edu
Advanced Photon Source, Sector 24
9700 S. Cass Avenue, Building 436 E001
Lemont, IL 60439
On May 4, 2026, at 13:05, Mark Rivers via Tech-talk <tech-talk at aps.anl.gov> wrote:
Folks,
I have a few old RHEL 6 systems running Dectris 100K detectors.  These cannot be upgraded to more recent Linux because of the driver for the GigaStar PCI card.
I have been able to build EPICS base and areaDetector for these up to base 7.0.7.
I just tried moving to base 7.0.10, and it fails as follows:
make -C O.linux-x86_64-rhel6 -f ../Makefile TOP=../../../../.. \
            T_A=linux-x86_64-rhel6 install
make[5]: Entering directory `/corvette/usr/local/epics/base-7.0.10/modules/database/src/ioc/O.linux-x86_64-rhel6'
perl -CSD /corvette/usr/local/epics/base-7.0.10/bin/linux-x86_64-rhel6/genVersionHeader.pl   -t ../../../../.. -N EPICS_VCS_VERSION -V "" ../O.Common/epicsVCS.h
Keeping VCS header ../O.Common/epicsVCS.h
    EPICS_VCS_VERSION = ""
perl -CSD ../../../../../bin/linux-x86_64-rhel6/dbdToMD.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuConvert.md ../bpt/menuConvert.dbd.pod
Pod::Simple version 3.27 required--this is only version 3.13 at /corvette/usr/local/epics/base-7.0.10/bin/linux-x86_64-rhel6/../../lib/perl/Pod/Markdown.pm line 21.
BEGIN failed--compilation aborted at /corvette/usr/local/epics/base-7.0.10/bin/linux-x86_64-rhel6/../../lib/perl/Pod/Markdown.pm line 21.
Compilation failed in require at (eval 6) line 3.
        ...propagated at /usr/share/perl5/base.pm line 94.
BEGIN failed--compilation aborted at /corvette/usr/local/epics/base-7.0.10/bin/linux-x86_64-rhel6/../../lib/perl/EPICS/PodMD.pm line 8.
Compilation failed in require at ../../../../../bin/linux-x86_64-rhel6/dbdToMD.pl line 21.
BEGIN failed--compilation aborted at ../../../../../bin/linux-x86_64-rhel6/dbdToMD.pl line 21.
The issue is the version of POD:Simple. RHEL 6 only provides 3.13 but it appears that base requires 3.27.
I did not see anything in the base release notes about what versions of Linux are supported in 7.0.10.
I understand if there is a need to drop support for RHEL 6, I can continue to use base 7.0.7 for that arch.  However, if this was unintentional I thought I would let folks know about the issue.
Base 7.0.10 and RHEL 6 Mark Rivers via Tech-talk
Prev: Base 7.0.10 and RHEL 6 Mark Rivers via Tech-talk
Next: Re: Base 7.0.10 and RHEL 6 Érico Nogueira Rolim via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
ANJ, 04 May 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
