1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Base 7.0.10 and RHEL 6
From: Abdalla Ahmad via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, Érico Nogueira Rolim <erico.rolim at lnls.br>
Date: Tue, 5 May 2026 08:33:34 +0000
Hi Erico
This looks interesting; we could benefit from this setup for our Dectris 300K. Please let us know once you have solid documentation. Thanks!
Best Regards,
Abdalla.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Érico Nogueira Rolim via Tech-talk <tech-talk at aps.anl.gov>
Sent: Monday, May 4, 2026 9:16 PM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Hi Mark!
On 5/4/26 15:04, Mark Rivers via Tech-talk wrote:
Folks,
I have a few old RHEL 6 systems running Dectris 100K detectors.  These cannot be upgraded to more recent Linux because of the driver for the GigaStar PCI card.
I have been able to build EPICS base and areaDetector for these up to base 7.0.7.
We are currently testing a setup running the old Linux kernel and camserver inside a VM with PCI-passthrough, and running the IOC outside of the VM on a modern distro, with a shared mount for the camserver files.
It's worked for initial tests, but we haven't tried putting it in production just yet.
If this setup would be useful to you, let me know and I'll see if we can speed up documenting the setup.
I just tried moving to base 7.0.10, and it fails as follows:
make -C O.linux-x86_64-rhel6 -f ../Makefile TOP=../../../../.. \
            T_A=linux-x86_64-rhel6 install
make[5]: Entering directory `/corvette/usr/local/epics/base-7.0.10/modules/database/src/ioc/O.linux-x86_64-rhel6'
perl -CSD /corvette/usr/local/epics/base-7.0.10/bin/linux-x86_64-rhel6/genVersionHeader.pl   -t ../../../../.. -N EPICS_VCS_VERSION -V "" ../O.Common/epicsVCS.h
Keeping VCS header ../O.Common/epicsVCS.h
    EPICS_VCS_VERSION = ""
perl -CSD ../../../../../bin/linux-x86_64-rhel6/dbdToMD.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuConvert.md ../bpt/menuConvert.dbd.pod
Pod::Simple version 3.27 required--this is only version 3.13 at /corvette/usr/local/epics/base-7.0.10/bin/linux-x86_64-rhel6/../../lib/perl/Pod/Markdown.pm line 21.
BEGIN failed--compilation aborted at /corvette/usr/local/epics/base-7.0.10/bin/linux-x86_64-rhel6/../../lib/perl/Pod/Markdown.pm line 21.
Compilation failed in require at (eval 6) line 3.
        ...propagated at /usr/share/perl5/base.pm line 94.
BEGIN failed--compilation aborted at /corvette/usr/local/epics/base-7.0.10/bin/linux-x86_64-rhel6/../../lib/perl/EPICS/PodMD.pm line 8.
Compilation failed in require at ../../../../../bin/linux-x86_64-rhel6/dbdToMD.pl line 21.
BEGIN failed--compilation aborted at ../../../../../bin/linux-x86_64-rhel6/dbdToMD.pl line 21.
The issue is the version of POD:Simple. RHEL 6 only provides 3.13 but it appears that base requires 3.27.
I did not see anything in the base release notes about what versions of Linux are supported in 7.0.10.
I understand if there is a need to drop support for RHEL 6, I can continue to use base 7.0.7 for that arch.  However, if this was unintentional I thought I would let folks know about the issue.
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: Base 7.0.10 and RHEL 6 Wlodek, Jakub via Tech-talk
Base 7.0.10 and RHEL 6 Mark Rivers via Tech-talk
Re: Base 7.0.10 and RHEL 6 Érico Nogueira Rolim via Tech-talk
Prev: Re: Base 7.0.10 and RHEL 6 James P. Withrow via Tech-talk
Next: Re: Base 7.0.10 and RHEL 6 Wlodek, Jakub via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
ANJ, 05 May 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
