1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: PVA custom structs
From: "Sukhanov, Andrei via Tech-talk" <tech-talk at aps.anl.gov>
To: Heinz Junkes <junkes at fhi-berlin.mpg.de>, EPICS Tech-Talk <tech-talk at aps.anl.gov>
Date: Sat, 9 May 2026 16:01:40 +0000
Run a 'converter' to scalars or array of ushorts would be the best choice.
/Andrey
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Heinz Junkes via Tech-talk <tech-talk at aps.anl.gov>
Sent: Saturday, May 9, 2026 6:14:31 AM
To: EPICS Tech-Talk <tech-talk at aps.anl.gov>
Here’s some more information on that from the Archiver Appliance’s log file.
Are these the main pieces of information to the issue?
2026-05-09 11:59:19,580 ERROR [JCA Command Thread] pv.EPICS_V4_PV (EPICS_V4_PV.java:240) - Cannot determine the timestamp bitset for PV FHIFEL:llpg_1. This means we may not save any data at all for this PV.
java.lang.NullPointerException: Cannot invoke "org.epics.pva.data.PVAStructure.get(String)" because "timeStampPVStructure" is null
2026-05-09 11:53:19,635 ERROR [Engine scheduler for misc tasks.] metadata.MetaGet (MetaGet.java:225) - Cannot determine DBR type for pv FHIFEL:llpg_1
2026-05-09 11:58:36,583 INFO [http-nio-17666-exec-4] engine.BPLServlet (BPLServlet.java:102) - Beginning request into Engine servlet /getVersion
2026-05-09 11:58:36,583 INFO [http-nio-17666-exec-4] common.BasicDispatcher (BasicDispatcher.java:44) - Servicing /getVersion
2026-05-09 11:59:19,450 INFO [Event bus] pv.EPICS_V4_PV (EPICS_V4_PV.java:338) - Connecting to PV FHIFEL:llpg_1
2026-05-09 11:59:19,478 INFO [JCA Command Thread] pv.EPICS_V4_PV (EPICS_V4_PV.java:221) - channelStateChanged:SEARCHING FHIFEL:llpg_1
2026-05-09 11:59:19,479 INFO [UDP4-receiver /0.0.0.0:59609] pv.EPICS_V4_PV (EPICS_V4_PV.java:221) - channelStateChanged:FOUND FHIFEL:llpg_1
2026-05-09 11:59:19,481 INFO [TCP receiver /141.14.135.0:37864] pv.EPICS_V4_PV (EPICS_V4_PV.java:221) - channelStateChanged:CONNECTED FHIFEL:llpg_1
2026-05-09 11:59:19,580 INFO [JCA Command Thread] pv.EPICS_V4_PV (EPICS_V4_PV.java:235) - Construct the fieldValuesCache for PV FHIFEL:llpg_1
2026-05-09 11:59:19,580 INFO [JCA Command Thread] pv.EPICS_V4_PV (EPICS_V4_PV.java:248) - Type from structure in monitorConnect is structure
ushort Ch1_Width
ushort Ch2_Width
ushort Ch1_Delay
ushort Ch2_Delay
ushort Ch1_ExtraDly
ushort Ch2_ExtraDly
ushort Ch1_Atten
ushort Ch2_Atten
2026-05-09 11:59:19,580 INFO [JCA Command Thread] pv.EPICS_V4_PV (EPICS_V4_PV.java:259) - Determined ArchDBRTypes for FHIFEL:llpg_1 as DBR_V4_GENERIC_BYTES
2026-05-09 11:59:19,580 ERROR [JCA Command Thread] pv.EPICS_V4_PV (EPICS_V4_PV.java:431) - exception when reading pv
java.lang.reflect.InvocationTargetException: null
at jdk.internal.reflect.DirectConstructorHandleAccessor.newInstance(DirectConstructorHandleAccessor.java:72) ~[?:?]
at java.lang.reflect.Constructor.newInstanceWithCaller(Constructor.java:502) ~[?:?]
at java.lang.reflect.Constructor.newInstance(Constructor.java:486) ~[?:?]
at org.epics.archiverappliance.engine.pv.EPICS_V4_PV.fromStructure(EPICS_V4_PV.java:277) ~[classes/:?]
at org.epics.archiverappliance.engine.pv.EPICS_V4_PV.subscribe(EPICS_V4_PV.java:427) ~[classes/:?]
at org.epics.archiverappliance.engine.pv.EPICS_V4_PV.handleConnected(EPICS_V4_PV.java:388) ~[classes/:?]
at org.epics.archiverappliance.engine.pv.JCACommandThread.run(JCACommandThread.java:189) [classes/:?]
Caused by: java.lang.NullPointerException: Cannot invoke "org.epics.pva.data.PVAStructure.get(String)" because "timeStampPVStructure" is null
at org.epics.archiverappliance.common.TimeUtils.convertFromPVTimeStamp(TimeUtils.java:533) ~[classes/:?]
at edu.stanford.slac.archiverappliance.PB.data.PBV4GenericBytes.<init>(PBV4GenericBytes.java:68) ~[classes/:?]
at jdk.internal.reflect.DirectConstructorHandleAccessor.newInstance(DirectConstructorHandleAccessor.java:62) ~[?:?]
... 6 more
Danke, Heinz
> On 8. May 2026, at 17:10, Heinz Junkes (FHI) via Tech-talk <tech-talk at aps.anl.gov> wrote:
> Hi,
> I am running a P4P server on an embedded system and offer the following structure:
> epics@felpvagate:~$ pvinfo FHIFEL:llpg_1
> FHIFEL:llpg_1
> Server: 10.0.0.87:5075
> Type:
> structure
> ushort Ch1_Width
> ushort Ch2_Width
> ushort Ch1_Delay
> ushort Ch2_Delay
> ushort Ch1_ExtraDly
> ushort Ch2_ExtraDly
> ushort Ch1_Atten
> ushort Ch2_Atten
> Unfortunately, the archiverAppliance cannot monitor/archive these.
> Was ist der beste Weg um diese Werte zu archivieren?
> 1.) Should the 8 values be made available as ‘individual’ scalar PVs on the embedded system as well?
> 2.) Run a ‘converter’ on another system that maps the custom struct to scalar PVs?
> 3.) Another idea ?
> Danke Heinz
> Fritz-Haber-Institut | Phone: (+49 30) 8413-4270
> Heinz Junkes | VC: https://zoom.fhi.berlin/junkes
> Faradayweg 4-6 | Visitors: Hittorfstrasse 29 (Bld S (Slough House) )
> D - 14195 Berlin
> “Sorry I’m a bit late, had a terrible time…
> All sort of things cropping up at the last moment. Uh, how are we for time?”
> —Zarquon's address to Milliways
PVA custom structs Heinz Junkes (FHI) via Tech-talk
Re: PVA custom structs Heinz Junkes via Tech-talk
Prev: Re: PVA custom structs Heinz Junkes via Tech-talk
Next: Pva Charter via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Next: Re: PVA custom structs Ralph Lange via Tech-talk
ANJ, 11 May 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
