1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: PVA custom structs
From: Heinz Junkes via Tech-talk <tech-talk at aps.anl.gov>
To: Heinz Junkes <junkes at fhi-berlin.mpg.de>
Cc: "Shankar, Murali" <mshankar at slac.stanford.edu>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 12 May 2026 17:57:30 +0200
in engine/log it looks ok for me (I have also introduced alarm fields)?
2026-05-12 17:48:15,540 INFO  [JCA Command Thread] pv.EPICS_V4_PV (EPICS_V4_PV.java:259) - Determined ArchDBRTypes for FHIFEL:llpg_1 as DBR_V4_GENERIC_BYTES
2026-05-12 17:48:17,474 INFO  [UDP4-receiver /0.0.0.0:59609] pv.EPICS_V4_PV (EPICS_V4_PV.java:221) - channelStateChanged:FOUND FHIFEL:llpg_1
2026-05-12 17:48:17,475 INFO  [TCP receiver /141.14.135.0:43970] pv.EPICS_V4_PV (EPICS_V4_PV.java:221) - channelStateChanged:CONNECTED FHIFEL:llpg_1
2026-05-12 17:48:17,544 INFO  [JCA Command Thread] pv.EPICS_V4_PV (EPICS_V4_PV.java:235) - Construct the fieldValuesCache for PV FHIFEL:llpg_1
2026-05-12 17:48:17,544 INFO  [JCA Command Thread] pv.EPICS_V4_PV (EPICS_V4_PV.java:248) - Type from structure in monitorConnect is structure
    ushort Ch1_Width
    ushort Ch2_Width
    ushort Ch1_Delay
    ushort Ch2_Delay
    ushort Ch1_ExtraDly
    ushort Ch2_ExtraDly
    ushort Ch1_Atten
    ushort Ch2_Atten
    structure timeStamp
        long secondsPastEpoch
        uint nanoseconds
        uint userTag
    structure alarm
        int severity
        int status
        string message
2026-05-12 17:48:17,544 INFO  [JCA Command Thread] pv.EPICS_V4_PV (EPICS_V4_PV.java:259) - Determined ArchDBRTypes for FHIFEL:llpg_1 as DBR_V4_GENERIC_BYTES
2026-05-12 17:49:51,502 INFO  [http-nio-17666-exec-5] engine.BPLServlet (BPLServlet.java:102) - Beginning request into Engine servlet /getVersion
2026-05-12 17:49:51,502 INFO  [http-nio-17666-exec-5] common.BasicDispatcher (BasicDispatcher.java:44) - Servicing /getVersion
Unfortunately, nothing is archived, though…
Heinz
> On 12. May 2026, at 17:12, Heinz Junkes via Tech-talk <tech-talk at aps.anl.gov> wrote:
> I added the timeStamp to the structure:
> epics@aaV:~$ pvinfo FHIFEL:llpg_1
> FHIFEL:llpg_1
> Server: 141.14.134.173:5075
> Type:
>    structure
>        ushort Ch1_Width
>        ushort Ch2_Width
>        ushort Ch1_Delay
>        ushort Ch2_Delay
>        ushort Ch1_ExtraDly
>        ushort Ch2_ExtraDly
>        ushort Ch1_Atten
>        ushort Ch2_Atten
>        structure timeStamp
>            uint nanoseconds
>            uint userTag
> pvmonitor seems to work:
> epics@aaV:~$ pvmonitor FHIFEL:llpg_1
> FHIFEL:llpg_1 structure
>    ushort Ch1_Width 0
>    ushort Ch2_Width 1122
>    ushort Ch1_Delay 946
>    ushort Ch2_Delay 1342
>    ushort Ch1_ExtraDly 10000
>    ushort Ch2_ExtraDly 2000
>    ushort Ch1_Atten 3
>    ushort Ch2_Atten 31
>    structure timeStamp
>        long secondsPastEpoch 1147446330
>        uint nanoseconds 448787927
>        uint userTag 0
>    ushort Ch1_Atten 4
>    structure timeStamp
>        long secondsPastEpoch 1147446570
>        uint nanoseconds 69449424
>    ushort Ch1_Atten 3
>    structure timeStamp
>        long secondsPastEpoch 1147446572
>        uint nanoseconds 722922325
> Unfortunately, however, the PV is not archived:
> <PastedGraphic-1.png>
> Heinz
>> On 11. May 2026, at 20:18, Shankar, Murali via Tech-talk <tech-talk at aps.anl.gov> wrote:
>> Wouldn't you need a IOC timestamp? Maybe alarm information? Something like
>> alarm_t alarm
>>    int severity
>>    int status
>>    string message
>> time_t timeStamp
>>    int nanoseconds
>>    int userTag
>> Regards,
>> Murali
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: PVA custom structs Heinz Junkes via Tech-talk
Re: PVA custom structs Shankar, Murali via Tech-talk
Prev: Re: PVA custom structs Heinz Junkes via Tech-talk
Next: Re: PVA custom structs Heinz Junkes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
ANJ, 12 May 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
