1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: EPICS modulle for Piezosystem Jena's piezo controller NV 40/1 CLE
From: Torsten Bögershausen via Tech-talk <tech-talk at aps.anl.gov>
To: LiangChih Chiang <yehnan174 at gmail.com>, tech-talk at aps.anl.gov
Date: Mon, 18 May 2026 12:34:28 +0200
I would say, in opposite to other opinions,
that developing a model 3 driver makes sense.
However, the attached files are jpg and part
of the bigger spec.
The mentioned poll() function needs to find out,
where the positioner is - in closed loop.
If it is homed/referenced/calibrated.
That code needs to be somewhere,
either you use streamDevice or a proper model 3 driver.
In streamDevice you set up db files, which may feel easier
for some people.
The model 3 driver involves some C/C++ coding.
Please let me know, if you want help here.
BR
/Torsten
On 2026-05-18 09:40, LiangChih Chiang via Tech-talk wrote:
Dear EPICS mates,
I need to control a piezo actuator via
Piezosystem Jena's piezo controller NV 40/1 CLE,
which is very old and discontinued.
Its commands are extremely simple:(please see attach files)
i1  activate remote control
i0 deactivate remote control
cl  closed loop on
ol  closed loop off
rd  read a value (µm for closed loop, volt for open loop)
wr,<value>  write a value (µm for closed loop, volt for open loop)
I'm wondering if it's possible to develop
a "Model 3" motor driver for it.
Do you guys have experience for similiar suuch simple devices?
Re: EPICS modulle for Piezosystem Jena's piezo controller NV 40/1 CLE LiangChih Chiang via Tech-talk
Prev: Re: EPICS modulle for Piezosystem Jena's piezo controller NV 40/1 CLE Abdalla Ahmad via Tech-talk
Next: Re: EPICS modulle for Piezosystem Jena's piezo controller NV 40/1 CLE LiangChih Chiang via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: EPICS modulle for Piezosystem Jena's piezo controller NV 40/1 CLE Torsten Bögershausen via Tech-talk
ANJ, 02 Jun 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
