Hi Mark,
Did you try looking at `dmesg` or `journalctl` at the host to check if there is any information about lost usb devices? You mentioned that `lsusb` and udev was being activated correctly, but if I understood correctly, that was after reconnection. It would make sense that the device was recognized again after this reconnection, but could be lost before.
Hope this helps.
Folks,
I am trying to get a LakeShore 335 temperature controller working with EPICS. It has both GPIB and USB interfaces. The USB operates as a serial port at 57600 baud, 7 data bits, odd parity. Yesterday I connected it to the USB port on Linux, where it was seen
as /dev/ttyUSB0. I set up a udev rule to always connect that vendor, model, and serial number to /dev/lakeshore-335-1 with 666 permissions. I loaded an IOC with both an asyn record for interactive testing, as well as the LakeShore335.db file which uses StreamDevice
here:
https://github.com/epics-modules/ip/blob/master/ipApp/Db/LakeShore335.db
Initially it worked fine, I could communicate both with the asynRecord and with the database. However, after some time it stopped responding to any commands sent to it. When I disconnect and reconnect the USB cable to the Linux machine it is immediately seen
OK, it shows up in lsusb and the udev rule is being activated correctly, so I know the low-level USB interface on the device is working. I have tried power-cycling several times.
Does anyone know why this might be happening? There is a Remote/Local switch on the front panel, but it does not communicate in either mode. Is there some setting that could have been flipped or something?
Augusto Yoshio Horita Eng. de Controle e Automação - Unicamp cel.: (19) 98781-1429
- Re: LakeShore 335 problem Mark Rivers via Tech-talk
- LakeShore 335 problem Mark Rivers via Tech-talk
2025
<2026>
2025
<2026>
ANJ, 19 May 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
