1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: EPICS modulle for Piezosystem Jena's piezo controller NV 40/1 CLE
From: "Peterson, Kevin M. via Tech-talk" <tech-talk at aps.anl.gov>
To: LiangChih Chiang <yehnan174 at gmail.com>, Abdalla Ahmad <Abdalla.Ahmad at sesame.org.jo>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 21 May 2026 21:43:13 +0000
There is streamDevice support for the Jena NV40 and NV40/3 CLE in the ip module:
github.com/epics-modules/ip
Kevin
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Abdalla Ahmad via Tech-talk <tech-talk at aps.anl.gov>
Sent: Monday, May 18, 2026 5:00 AM
Cc: tech-talk at aps.anl.gov
I am not saying it is not possible; it just does not make sense, not to mention the effort you will spend in developing a motor driver instead of relying on something simple like a stream device. A model 3 motor driver consists of two C++ classes inherting from asynMotorController and asynMotorAxis classes which are part of the motor support module. You will need to implement some methods like polling the controller, setting/reading the position, etc. Next, you will create your dbd files and call your driver into the st.cmd of your IOC, not to mention the motor record GUI. The motor support module contains a lot of motion controllers support module.
You can choose this or just create a stream device IOC with 6 PVs like you requested.
Best Regards,
Abdalla.
Sent: Monday, May 18, 2026 12:00 PM
To: Abdalla Ahmad <Abdalla.Ahmad at sesame.org.jo>
Cc: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
> I don't think developing a model 3 motor driver for this piezo controller makes sense.
I agree.
But I would like to provide motor record for this piezo controller,
in order to treat it like a motor.
>Model 3 motor driver requires other parameters such as velocity, motor resolution, homing, jogging, etc.
Can't I just provide dummy values for these parameters?
On Mon, May 18, 2026 at 4:49 PM Abdalla Ahmad <Abdalla.Ahmad at sesame.org.jo<mailto:Abdalla.Ahmad at sesame.org.jo>> wrote:
Hi
I don't think developing a model 3 motor driver for this piezo controller makes sense. Model 3 motor driver requires other parameters such as velocity, motor resolution, homing, jogging, etc. A stream device interface works the best for your case.
Best Regards,
Abdalla.
From: Tech-talk <tech-talk-bounces at aps.anl.gov<mailto:tech-talk-bounces at aps.anl.gov>> on behalf of LiangChih Chiang via Tech-talk <tech-talk at aps.anl.gov<mailto:tech-talk at aps.anl.gov>>
Sent: Monday, May 18, 2026 10:40 AM
To: tech-talk at aps.anl.gov<mailto:tech-talk at aps.anl.gov> <tech-talk at aps.anl.gov<mailto:tech-talk at aps.anl.gov>>
Subject: EPICS modulle for Piezosystem Jena's piezo controller NV 40/1 CLE
Dear EPICS mates,
I need to control a piezo actuator via
Piezosystem Jena's piezo controller NV 40/1 CLE,
which is very old and discontinued.
Its commands are extremely simple:(please see attach files)
i1  activate remote control
i0  deactivate remote control
cl  closed loop on
ol  closed loop off
rd  read a value (µm for closed loop, volt for open loop)
wr,<value>  write a value  (µm for closed loop, volt for open loop)
I'm wondering if it's possible to develop
a "Model 3" motor driver for it.
Do you guys have experience for similiar suuch simple devices?
Re: EPICS modulle for Piezosystem Jena's piezo controller NV 40/1 CLE LiangChih Chiang via Tech-talk
Re: EPICS modulle for Piezosystem Jena's piezo controller NV 40/1 CLE Abdalla Ahmad via Tech-talk
Prev: SNS Controls Software Engineer Position Justice, T. Alan via Tech-talk
Next: Re: EPICS modulle for Piezosystem Jena's piezo controller NV 40/1 CLE LiangChih Chiang via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: EPICS modulle for Piezosystem Jena's piezo controller NV 40/1 CLE Abdalla Ahmad via Tech-talk
ANJ, 21 May 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
