1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Inquiry about replacing SIS3820 with USB-CTR08 for 6-channel data acquisition
From: zhaoying--- via Tech-talk <tech-talk at aps.anl.gov>
To: <rivers at cars.uchicago.edu>, <tech-talk at aps.anl.gov>
Cc: zhangzh at sari.ac.cn
Date: Fri, 22 May 2026 10:52:03 +0800
Dear Mark,
I hope this message finds you well.
We are currently using the SIS3820 multi-channel scaler (MCS) for data acquisition, collecting data from 6 channels. The maximum sampling rate we require is 30 MHz, which meets our current experimental needs.
As the SIS3820 is now obsolete, we are actively looking for a reliable replacement. I understand that the USB-CTR08 may be a possible alternative, especially given that it works with EPICS and supports MCS mode.
Before making a decision, I would like to ask for your advice on the following:
  1. Is the USB-CTR08 a suitable replacement for the SIS3820 in terms of performance and functionality, given our requirement of 6 channels and a 30 MHz sampling rate?
  2. If it is a viable replacement, what steps would we need to take to migrate from the SIS3820 to the USB-CTR08 in terms of hardware integration, driver installation, and application-level changes (e.g., EPICS record updates)?
Any guidance or documentation you could share would be very helpful.
Thank you very much for your time and support.
Best regards,
Ying
Prev: Re: EPICS modulle for Piezosystem Jena's piezo controller NV 40/1 CLE LiangChih Chiang via Tech-talk
Next: What is serving these PVs? David Bracey via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: SNS Controls Software Engineer Position Justice, T. Alan via Tech-talk
ANJ, 27 May 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
