Hi David,
Just as most of us do not have enough time (also probably not enough capability) to understand the sophisticated source codes of EPICS cores, I simply
synthesized epicsEnvSet("EPICS_IOC_IGNORE_SERVERS", "qsrv qsrv2 rsrv pva pvxs")
based on your initial message and LLM’s suggestions. Honestly I only have a decent understanding of RSRV. For that variable, you can
put any strings (event duplicated ones) separated by spaces.
One correction about my statement #1 below:
the right location in
st.cmd is
BEFORE xxx_registerRecordDeviceDriver pdbbase,
more ahead of iocInit.
Have a great weekend!
Yong
Date: Thursday, May 28, 2026 at 10:39 AM
Hi Yong – mostly playing around, I like to understand how things work.
I am curious about where you have included “pva” and “pvxs” in the
EPICS_IOC_IGNORE_SERVERS env variable. Does this do anything, to your knowledge? My understanding was that RSRV = CA, QSRV = PVA and QSRV2 = PVXS. So already having “qsrv” and “qsrv2” in the value would seem make “pva”
and “pvxs” redundant.
Date: Thursday, May 28, 2026 at 9:01 AM
Hi David,
What is your use case for using ‘EPICS_IOC_IGNORE_SERVERS’, just for playing around? I did a quick Google search (and quick chats with Gemini and ChatGPT). My Google search points
to two sites and one is this tech-talk thread showing
one interesting use case.
This is my first time to pay attention to that EPICS environment variable. Naturally I want to give a quick try. To further train Google and other AI models, I am spending a few minutes on posting what I have found out:
1. My EPICS base is R7.0.5. It seems I have to set this variable, i.e.
epicsEnvSet("EPICS_IOC_IGNORE_SERVERS", "qsrv qsrv2 rsrv pva pvxs"), before
dbLoadDatabase. Both Gemini and ChatGPT say something like this “You define this variable in your host environment or directly in your IOC's startup script (st.cmd) before calling
iocInit.”. That makes perfect sense. However, to me, the right location in
st.cmd is BEFORE dbLoadDatabase, more ahead of iocInit.
2. In the EPICS base Release
Note, it mentions this variable (along with dbServer API which my Gemini chat also mentions): "separated by spaces if more than one should be ignored". That is why I use
epicsEnvSet("EPICS_IOC_IGNORE_SERVERS", "qsrv qsrv2 rsrv pva pvxs").
However, it seems to me only one IOC server layer can be ignored at the moment: rsrv which is the traditional IOC server.
3. To stop PVA server, I simply type stopPVAServer in the EPICS shell.
Cheers,
Yong
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of David Bracey via Tech-talk <tech-talk at aps.anl.gov>
Date: Wednesday, May 27, 2026 at 2:40 PM
Pierrick Hanlet caught my mistake – QSRV was also running. When I added that to EPICS_IOC_IGNORE_SERVERS, the PVs went away as expected.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
Date: Wednesday, May 27, 2026 at 1:37 PM
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Subject: Re: What is serving these PVs?
On Wed, 27 May 2026 at 19:54, David Bracey via Tech-talk <tech-talk at aps.anl.gov> wrote:
I have all of the servers disabled on this IOC:
epics> dbsr
No server layers registered with IOC
epics> dbl
ABC:XYZ_CTRL_SYS:AMP
ABC:XYZ_CTRL_SYS:FREQ
ABC:XYZ_CTRL_SYS:TIME
ABC:XYZ_CTRL_SYS:COS
ABC:XYZ_CTRL_SYS:SIN
However the PVs are still being served:
dbracey@xyzzy:~$ pvxget ABC:XYZ_CTRL_SYS:AMP
value double = 10
alarm.severity int32_t = 0
epics>
epicsPrtEnvParams
EPICS_IOC_IGNORE_SERVERS: rsrv qsrv2
I am just guessing at how things work, so I must have made a wrong assumption.
Can someone explain what’s going on?
What does `pvinfo ...` show?
Maybe another instance of the IOC running...
Cheers,
~Ralph
- What is serving these PVs? David Bracey via Tech-talk
- Re: What is serving these PVs? Ralph Lange via Tech-talk
- Re: What is serving these PVs? David Bracey via Tech-talk
- Re: What is serving these PVs? Hu, Yong via Tech-talk
Re: epics-ioc-runner: A lightweight systemd & procServ IOC Han Lee via Tech-talk
2025
<2026>
iocStats CPU time seems wrong Mark Rivers via Tech-talk
2025
<2026>
