1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: PVA OUT Links in EPICS:
From: Varuna Crishan Meddage via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 8 Jun 2026 23:13:50 +0000
I have an analog output record which outputs to another analog output record (published by different IOC) as defined below
record(ao, "PIP2:CTRL_MPS:4:AO:SLOW_SET:CH:1") {
    field(OUT, {pva:{"pv":"acq2106_345:4:AO:SLOW_SET:CH:1"}})
Just after IOC is initiated, dbpr query on this PV says it is undefined and severity is invalid.
After assigning a value to this PV, invalid severity disappears.
epics> dbpr PIP2:CTRL_MPS:4:AO:SLOW_SET:CH:1
AMSG:               ASG :               DESC:               DISA: 0
DISV: 1             NAME: PIP2:CTRL_MPS:4:AO:SLOW_SET:CH:1  NAMSG:
OMOD: 0             OVAL: 0             RBV : 0             RVAL: 0
SEVR: INVALID       STAT: UDF           TPRO: 0             VAL : 0
epics>
epics>
epics>
epics>
epics> dbpf PIP2:CTRL_MPS:4:AO:SLOW_SET:CH:1 5
DBF_DOUBLE:         5
epics>
epics>
OMOD: 0             OVAL: 5             RBV : 0             RVAL: 5
SEVR: NO_ALARM      STAT: NO_ALARM      TPRO: 0             VAL : 5
Is it possible to get rid of this invalid severity even before writing a value to this PV ?
I tried different tricks for example setting field(VAL, "0") and field(PINI, "YES"), but none of them was successful.
Thanks
Varuna Meddage
Re: PVA OUT Links in EPICS: Michael Davidsaver via Tech-talk
Re: PVA OUT Links in EPICS: Ralph Lange via Tech-talk
Prev: Re: CA Provider for PVXS André Favoto via Tech-talk
Next: Re: PVA OUT Links in EPICS: Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: CA Provider for PVXS Marks, Nicholas via Tech-talk
ANJ, 09 Jun 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
