1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Strange problem linking a library on windows-x64
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Tue, 9 Jun 2026 21:46:40 +0000
Folks,
I am having a strange problem linking a library on windows-x64 (dynamic build).  The library compiles and links fine on windows-x64-static (static build).
On windows-x64 the library compiles fine, but generates this error when linking:
link -nologo -subsystem:windows -dll -LTCG -incremental:no -opt:ref -release  -MACHINE:X64           -out:ixwebsocket.dll -implib:ixwebsocket.lib     IXBench.obj IXCancellationRequest.obj IXConnectionState.obj IXDNSLookup.obj IXExponentialBackoff.obj IXGzipCodec.obj IXHttpClient.obj IXHttp.obj IXHttpServer.obj IXNetSystem.obj IXSelectInterrupt.obj IXSelectInterruptEvent.obj IXSelectInterruptFactory.obj IXSelectInterruptPipe.obj IXSetThreadName.obj IXSocketAppleSSL.obj IXSocketConnect.obj IXSocket.obj IXSocketFactory.obj IXSocketMbedTLS.obj IXSocketOpenSSL.obj IXSocketServer.obj IXSocketTLSOptions.obj IXStrCaseCompare.obj IXUdpSocket.obj IXUrlParser.obj IXUserAgent.obj IXUuid.obj IXWebSocketCloseConstants.obj IXWebSocket.obj IXWebSocketHandshake.obj IXWebSocketHttpHeaders.obj IXWebSocketPerMessageDeflateCodec.obj IXWebSocketPerMessageDeflate.obj IXWebSocketPerMessageDeflateOptions.obj IXWebSocketProxyServer.obj IXWebSocketServer.obj IXWebSocketTransport.obj        ws2_32.lib crypt32.lib bcrypt.lib
Generating code
Finished generating code
"Installing shared library ../../../../bin/windows-x64/ixwebsocket.dll"
"Installing library ../../../../lib/windows-x64/ixwebsocket.lib"
installEpics.pl: No such file 'ixwebsocket.lib' at H:/epics-devel/base-7.0.10/bin/windows-x64/installEpics.pl line 54.
make[3]: *** [H:/epics-devel/base-7.0.10/configure/RULES_BUILD:489: ../../../../lib/windows-x64/ixwebsocket.lib] Error 2
make[3]: Leaving directory 'J:/epics/devel/quadEM/quadEMApp/FX4Src/ixwebsocket/O.windows-x64'
make[2]: *** [H:/epics-devel/base-7.0.10/configure/RULES_ARCHS:58: install.windows-x64] Error 2
make[2]: Leaving directory 'J:/epics/devel/quadEM/quadEMApp/FX4Src/ixwebsocket'
make[1]: *** [H:/epics-devel/base-7.0.10/configure/RULES_DIRS:85: FX4Src/ixwebsocket.install] Error 2
make[1]: Leaving directory 'J:/epics/devel/quadEM/quadEMApp'
make: *** [H:/epics-devel/base-7.0.10/configure/RULES_DIRS:85: quadEMApp.install] Error 2
Note that the link command did not generate an error.  However, there is an error when it tries to install the ixwebsocket.lib.  The problem is that the library file is not being created.
If I cd to the O.windows-x64 directory and manually type the "link" command it completes with no errors:
J:\epics\devel\quadEM\quadEMApp\FX4Src\ixwebsocket\O.windows-x64>link -nologo -subsystem:windows -dll -LTCG -incremental:no -opt:ref -release  -MACHINE:X64           -out:ixwebsocket.dll -implib:ixwebsocket.lib     IXBench.obj IXCancellationRequest.obj IXConnectionState.obj IXDNSLookup.obj IXExponentialBackoff.obj IXGzipCodec.obj IXHttpClient.obj IXHttp.obj IXHttpServer.obj IXNetSystem.obj IXSelectInterrupt.obj IXSelectInterruptEvent.obj IXSelectInterruptFactory.obj IXSelectInterruptPipe.obj IXSetThreadName.obj IXSocketAppleSSL.obj IXSocketConnect.obj IXSocket.obj IXSocketFactory.obj IXSocketMbedTLS.obj IXSocketOpenSSL.obj IXSocketServer.obj IXSocketTLSOptions.obj IXStrCaseCompare.obj IXUdpSocket.obj IXUrlParser.obj IXUserAgent.obj IXUuid.obj IXWebSocketCloseConstants.obj IXWebSocket.obj IXWebSocketHandshake.obj IXWebSocketHttpHeaders.obj IXWebSocketPerMessageDeflateCodec.obj IXWebSocketPerMessageDeflate.obj IXWebSocketPerMessageDeflateOptions.obj IXWebSocketProxyServer.obj IXWebSocketServer.obj IXWebSocketTransport.obj        ws2_32.lib crypt32.lib bcrypt.lib
Generating code
It should have created ixwebsocket.dll and ixwebsocket.lib.  However, when I look for those files in the O.windows-x64 directory only the .dll file exists, not the .lib file:
J:\epics\devel\quadEM\quadEMApp\FX4Src\ixwebsocket\O.windows-x64>dir *.lib *.dll
 Volume in drive J is people_rw
 Volume Serial Number is 5005-CD09
 Directory of J:\epics\devel\quadEM\quadEMApp\FX4Src\ixwebsocket\O.windows-x64
06/09/2026  04:37 PM           284,672 ixwebsocket.dll
               1 File(s)        284,672 bytes
               0 Dir(s)  9,569,302,556,672 bytes free
I have never seen this problem before.  Any idea what could cause it?
Re: Strange problem linking a library on windows-x64 J. Lewis Muir via Tech-talk
RE: Strange problem linking a library on windows-x64 Freddie Akeroyd - STFC UKRI via Tech-talk
Prev: Re: CA Provider for PVXS Marks, Nicholas via Tech-talk
Next: pvua: Another wrapper of pyepics and p4p Lewis, Laura via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: Wrapper of pyepics and p4p André Favoto via Tech-talk
Next: Re: Strange problem linking a library on windows-x64 J. Lewis Muir via Tech-talk
ANJ, 09 Jun 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
