1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: EPICS support for Fastech motors
From: Rea Domitrović via Tech-talk <tech-talk at aps.anl.gov>
To: Torsten Bögershausen <tboegi at edom.se>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 17 Jun 2026 13:34:29 +0000
Hi Torsten,
thanks for pointing me in the right direction. I'm looking at the manual and the source for other submodules now (motorSmarAct and motorAcs); I see that driver developers prefer to use octet-based communication rather than use the manufacturer-provided libraries. Is there a reason why that is the case, or is it simply that octet-based communicaton is more universal?
Further, the Fastech controller allows both octet-based communication and library-based communication, but octet-based communication requires the master to send a one-byte "sync number" which serves as an idempotence token. I assume it would be necessary to implement that myself; could I be using some sort of global variable, and how do I make sure that I never land on the same number twice in a row? Kind regards,
Rea
Sent: Wednesday, June 10, 2026 1:49:41 PM
To: Rea Domitrović; tech-talk at aps.anl.gov
Hej Rea,
I haven't worked with them, no.
If you have Ethernet (not to be confused with EtherCAT),
I read the manual as if they use UDP for communication,
and knowing that you can write a simple model 3 driver, I think.
(Other suggestions are welcome of course)
/Torsten
On 2026-06-10 12:52, Rea Domitrović via Tech-talk wrote:
> Hi all,
> I'm working with some Fastech Ezi-Servo II Plus-E motors, and I was
> wondering if someone had already worked with them and/or made an EPICS
> driver or Motor submodule? This particular line of motors and
> drives uses an Ethernet interface. Kind regards,
> Rea Domitrović
> Institut Ruđer Bošković
> Zagreb, Croatia
Oprez: Ova poruka stigla je od vanjskog pošiljatelja. Prije otvaranja poveznica ili privitaka provjerite pošiljatelja. Caution:This email originated from an external sender. Please verify the sender before opening links or attachments.
Re: EPICS support for Fastech motors Mark Rivers via Tech-talk
EPICS support for Fastech motors Rea Domitrović via Tech-talk
Re: EPICS support for Fastech motors Torsten Bögershausen via Tech-talk
Prev: Re: EPICS, RTEMS, Beaglebone Black Heinz Junkes via Tech-talk
Next: JCA 2.4.12 Released Shroff, Kunal via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: EPICS support for Fastech motors Torsten Bögershausen via Tech-talk
Next: Re: EPICS support for Fastech motors Mark Rivers via Tech-talk
ANJ, 17 Jun 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
