1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: IOCs - What are the built-in device types?
From: "Johnson, Andrew N. via Tech-talk" <tech-talk at aps.anl.gov>
To: David Bracey <dbracey at fnal.gov>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 17 Jun 2026 16:14:32 +0000
Hi Dave,
Great question, unfortunate answer: The current documentation doesn’t really cover those other DTYPs. Many of the record types have some documentation on their own soft and raw soft channel support, and there were entries in the Release Notes for some of the newer device supports that were integrated. The list of device support layers provided by Base can be found in the dbd/devSoft.dbd file of any EPICS 7 release after building, and it’s worth doing a Google search for any specific layer you’re interested in, but you might end up having to read the source to get some specific details at the moment (or ask here).
I may follow up with something written by Claude Code, which I have asked to fill in those gaps.
- Andrew
Complexity comes for free, Simplicity you have to work for.
On 6/17/26, 9:44 AM, "Tech-talk" <tech-talk-bounces at aps.anl.gov> wrote:
There are apparently built-in device types that provide various useful data sources:
  #  get the current time-of-day
  field(DTYP, "Soft Timestamp")
  field(INP,  "@%m/%d/%Y %H:%M:%S%z")
  # get the specified environment variable
  field(DTYP, "getenv")
  field(INP, "@ENGINEER")
Where can I find documentation of these built-in DTYP's?
Re: IOCs - What are the built-in device types? Johnson, Andrew N. via Tech-talk
IOCs - What are the built-in device types? David Bracey via Tech-talk
Prev: IOCs - What are the built-in device types? David Bracey via Tech-talk
Next: Re: EPICS support for Fastech motors Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Next: Re: IOCs - What are the built-in device types? Johnson, Andrew N. via Tech-talk
ANJ, 17 Jun 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
