1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: How to ensure with_ctrlvars monitor in PyEpics if PVs are initially unavailable
From: Matthew Newville via Tech-talk <tech-talk at aps.anl.gov>
To: "Wang, Lin" <wanglin at ihep.ac.cn>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 25 Jun 2026 15:33:19 +0000
Try this:
import time, epics
def onchange(pvname, value, **kws):
    print(f'Change {pvname=}, {value=}, units={kws.get(‘units', '?')}', list(kws.keys()))
mypv = epics.PV(‘calcExample', form='ctrl')
mypv.add_callback(on change)
for _ in range(10):
    time.sleep(1)
# or to get the units once:
mypv = epics.PV(‘calcExample') # the 'time' form is the default
mypv.wait_for_connection()
mypv_units = mypv.get_ctrlvars().get('units', '?’)
--Matthew Newville (newville at cars.uchicago.edu)
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Wang, Lin via Tech-talk <tech-talk at aps.anl.gov>
Date: Thursday, June 25, 2026 at 6:57 AM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: How to ensure with_ctrlvars monitor in PyEpics if PVs are initially unavailable
Dear all,
If the PV is ready, the following PyEpics code works normally and metadata is always available in callback,
import time, epics
def cb(**kw):
    print("units =", kw.get("units"))
pv = epics.PV("calcExample")
pv.wait_for_connection(timeout=5)
pv.add_callback(cb, with_ctrlvars=True)
time.sleep(10)
However, it seems that if the PV is not ready at first, the with_ctrlvars parameter will not take effect. In this case, even if the PV becomes accessible later, callback can never access metadata in subsequent updates.
So the questions: if PV metadata is intended to be available in callback no matter what status the PV is when calling add_callback(), is there any workaround? Or am I missing something?
Lin
How to ensure with_ctrlvars monitor in PyEpics if PVs are initially unavailable Wang, Lin via Tech-talk
Prev: Re: EPICS support for Fastech motors Mark Rivers via Tech-talk
Next: RE: [EXTERNAL] Re: 2026 white paper on EPICS vs commercial SCADA software Evans, Richard K. (GRC-H000) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: How to ensure with_ctrlvars monitor in PyEpics if PVs are initially unavailable Wang, Lin via Tech-talk
Next: RFC: add a mechanism to call epicsExit when signals are received Timothy Speight - STFC UKRI via Tech-talk
ANJ, 26 Jun 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
