1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Drivers for SPI-based stepper motor controllers
From: Rea Domitrović via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 9 Jul 2026 11:52:50 +0000
Hi all,
I'm working with an ST Microelectronics X-Nucleo IHM02A1 board, which is a daughterboard with two L6470 stepper motor controllers, plugged into a Raspberry Pi. The controllers talk over SPI, and if the headache wasn't bad enough, the two chips are daisy chained together and share the same chip-select line, rather than the standard SPI approach of giving each slave device its own line. I'm looking to develop an EPICS driver for those controllers so that we can use them to control steppers in the lab, and while there is an Asyn plug-in to enable SPI communication (https://urldefense.us/v3/__https://github.com/kek-acc/drvAsynSPI__;!!G_uCfscf7eWS!YDwm4DSyktS6YoYYgOF-qLUVEpcbvLzaBQ9yED4mw8XJRWQ5jbQ8o7rDnFRSAEHgNwWTkEjfdNC1ruyyDZJ5cnpiRT6Bvg$ ), I'm wondering if it might just be easier to bypass Asyn/model 3 and make a driver that talks to the motor record directly, using a different C++ library to handle the SPI communication.
So far, what I've figured out is: Due to the daisy chaining, data has to be sent interlaced, with zero-bytes for the L6470/motor we don't want to talk to. This means a single command with a 3-byte argument, such as jog, takes four SPI transmissions to fully propagate, each with one byte of the four-byte command frame. So, for example, jogging forward at 3/256 step/tick, for the device nearest the master:
Transmission 1: (0x00, 0x51)
Transmission 2: (0x00, 0x00)
Transmission 3: (0x00, 0x30)
Transmission 4: (0x00, 0x00)
This means, using Asyn, I would probably have to write custom writeController, readController and writeReadController functions with multiple pasynOctetSyncIO calls per command to make sure everything propagates through as needed. This doesn't sound too difficult, but that's assuming the Asyn/SPI driver even works as intended. On the other hand, bypassing Asyn would mean including a non-EPICS package as a dependency - I'm currently working with spidev_lib++.
Any suggestions and comments are more than welcome. Kind regards,
Rea Domitrović
Institut Ruđer Bošković
Zagreb, Croatia
Re: Drivers for SPI-based stepper motor controllers Torsten Bögershausen via Tech-talk
Prev: Re: [EXTERNAL] Gamma DIGITEL MPCq: mismatch after 0 bytes "" Abdalla Ahmad via Tech-talk
Next: support for LXI devices (Bustec ProDAQ 6150 specifically) Evans, Richard K. (GRC-H000) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Next: Re: Drivers for SPI-based stepper motor controllers Torsten Bögershausen via Tech-talk
ANJ, 10 Jul 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
