1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: RE: [EXTERNAL] Re: support for LXI devices (Bustec ProDAQ 6150 specifically)
From: "Evans, Richard K. \(GRC-H000\) via Tech-talk" <tech-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 10 Jul 2026 13:02:30 +0000
Hi Mark,  Thanks for the quick response.
Yes. the User Manul does say on pg 25 that the unit is a VXI-11 Device with an IVI/VXI plug-&-play compatible driver, but you’re right, the manual’s focus is mainly on the web-interface and it is not clear about the availability of SCPI commands or if there is another document such as a programming reference guide that is available. I have sent in a question to Bustec to clarify this and will share what I learn here when I hear from them.
In the meantime, thanks for sharing that you use StreamDevice to communicate with VXI-11 devices. If nothing else that gives me a solid direction to head in wrt to EPICS integration.
/Rich
Sent: Thursday, July 9, 2026 6:27 PM
To: tech-talk at aps.anl.gov; Evans, Richard K. (GRC-H000) <richard.k.evans at nasa.gov>
Subject: [EXTERNAL] Re: support for LXI devices (Bustec ProDAQ 6150 specifically)
You don't often get email from rivers at cars.uchicago.edu. Learn why this is important
CAUTION: This email originated from outside of NASA.  Please take care when clicking links or opening attachments.  Use the "Report Message" button to report suspicious messages to the NASA SOC.
Hi Richard,
I have used many VXI-11 devices.  VXI-11 is a subset of LXI.  I use StreamDevice to communicate, using SCPI (Standard Commands for Programmable Instruments) protocol.  The Bustec 6150 says it supports VXI-11.
I looked at the manual you referenced.  Unfortunately, they only discuss how to control it using the Web interface for configuration and Windows library they provide for acquisition.  I would guess that it probably uses the SCPI protocol for the actual low-level communication,  but this is not documented in that manual.  Without documentation for the SCPI commands you would be forced to use that Windows library.  Do you know if the SCPI commands are documented?
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Evans, Richard K. (GRC-H000) via Tech-talk <tech-talk at aps.anl.gov>
Sent: Thursday, July 9, 2026 4:05 PM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: support for LXI devices (Bustec ProDAQ 6150 specifically)
Hello,
Is anyone currently using LXI devices from a company called Bustec?
We are interested in using Bustec's ProDAQ 6150 (a 48-channel thermocouple measurement device) [1]. I checked the EPICS hardware support database and the Tech-Talk archives, but I couldn't find any mention of Bustec.
Since the ProDAQ 6150 is an LXI device, I know it can be interfaced with third-party software like EPICS. Before I attempt to develop support for it from scratch, I wanted to check here to see if anyone has already written something or has advice on the best approach (e.g., using asyn/StreamDevice) for Bustec specifically - or LXI devices in general.
For context, the device communication details are in section 6.3 (page 55) of the User Manual [1], which provides a few C code snippets demonstrating how to communicate with the device using their drivers.
Any advice or pointers would be greatly appreciated!
Rich
[1] User Manual: bustec.com/wp-content/uploads/2025/10/6150-XX-UM.pdf
Richard Evans, Information Systems
NASA's Neil A. Armstrong Test Facility
6100 Columbus Ave., Sandusky, Ohio 44870
mailto: richard.k.evans at nasa.gov
Re: [EXTERNAL] Re: support for LXI devices (Bustec ProDAQ 6150 specifically) Mark Rivers via Tech-talk
support for LXI devices (Bustec ProDAQ 6150 specifically) Evans, Richard K. (GRC-H000) via Tech-talk
Prev: Re: Drivers for SPI-based stepper motor controllers Rea Domitrović via Tech-talk
Next: Re: [EXTERNAL] Re: support for LXI devices (Bustec ProDAQ 6150 specifically) Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: support for LXI devices (Bustec ProDAQ 6150 specifically) Mark Rivers via Tech-talk
ANJ, 10 Jul 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
