1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: [EXTERNAL] Re: support for LXI devices (Bustec ProDAQ 6150 specifically)
From: Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov>
To: "Evans, Richard K. (GRC-H000)" <richard.k.evans at nasa.gov>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 15 Jul 2026 16:33:46 -0700
On 7/14/26 6:08 AM, Evans, Richard K. (GRC-H000) wrote:
Quick Update – Bustec sent me a copy of a full SCPI programming manual they have for the ProDAQ 6150. I would provide the link here for completeness, but they said it has not yet been added to the public website, but the SCPI manual, combined with the insights provided here by Mark (Thanks, Mark!) tell me that the Bustec ProDAQ 6150 can be integrated into EPICS if needed/required.
Michael – Thank you for the insights on the Digilent TC-32 and the “out-of-the-box” EPICS support provided through the measComp module. If that unit meets our needs it will be a very attractive option.
I am happy to be wrong about a "lack of openness"!
/Rich
From: Michael Davidsaver <mdavidsaver at gmail.com>
Sent: Sunday, July 12, 2026 7:11 PM
To: Evans, Richard K. (GRC-H000) <richard.k.evans at nasa.gov>
Cc: tech-talk at aps.anl.gov
Subject: [EXTERNAL] Re: support for LXI devices (Bustec ProDAQ 6150 specifically)
CAUTION: This email originated from outside of NASA.  Please take care when clicking links or opening attachments.  Use the "Report Message" button to report suspicious messages to the NASA SOC.
On 7/9/26 2:05 PM, Evans, Richard K. (GRC-H000) via Tech-talk wrote:
Hello,
Is anyone currently using LXI devices from a company called Bustec?
An absence of search results for "bustec python" is suggestive to me of a lack of openness.  That said, the code samples in linked manual look like any old VXI-11 device.  So it may just be that the commands obscured by this "helper" library.
If alternatives are practical, you might look into the TC-32.  Which is supported by the measComp epics module.
Any advice or pointers would be greatly appreciated!
As Mark mentioned, asyn+streamdevice seems like a reasonable approach for a device like this, where an IOC will likely just execute the same query command repeatedly.
With vxi11 devices, I usually start by exploring interactively from a python shell to learn about the inevitable quirks of these devices (there is always something odd...).
https://pyvisa.readthedocs.io/en/latest/
Also, wireshark has a vxi-11 protocol dissector.
https://wiki.wireshark.org/VXI-11
Rich
[1] User Manual: bustec.com/wp-content/uploads/2025/10/6150-XX-UM.pdf
Richard Evans, Information Systems
NASA's Neil A. Armstrong Test Facility
6100 Columbus Ave., Sandusky, Ohio 44870
mailto: richard.k.evans at nasa.gov
support for LXI devices (Bustec ProDAQ 6150 specifically) Evans, Richard K. (GRC-H000) via Tech-talk
Re: support for LXI devices (Bustec ProDAQ 6150 specifically) Michael Davidsaver via Tech-talk
RE: [EXTERNAL] Re: support for LXI devices (Bustec ProDAQ 6150 specifically) Evans, Richard K. (GRC-H000) via Tech-talk
Prev: RE: [EXTERNAL] Re: support for LXI devices (Bustec ProDAQ 6150 specifically) Evans, Richard K. (GRC-H000) via Tech-talk
Next: Receiving alarm notification from all records in database David Bracey via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Next: EPICS Integration With AVEVA PI using PI Web API Josh West via Tech-talk
ANJ, 16 Jul 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
