1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Create record name manifest during build
From: Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov>
To: "Johnson, Andrew N." <anj at anl.gov>, David Bracey <dbracey at fnal.gov>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 23 Jul 2026 18:18:34 -0700
On 7/23/26 1:52 PM, Johnson, Andrew N. via Tech-talk wrote:
We still use IRMIS here at APS for exactly that and have updated it to support EPICS 7, but I don't know if any other labs are still using it. Some of the online documentation may no longer be available, but this link provides the Agenda and slides from an IRMIS Collaboration meeting held in 2005 which should give you some ideas of its capabilities. We should be able to provide you a copy of our crawler code on request.
For maintaining an authoritative list of record names, there is also recsync + channelfinder.
https ://github.com/ChannelFinder/recsync
The short version.  recsync is an EPICS support module which lives in each IOC.  At the end of IOC startup it knows how to find a channelfinder database service and push a list of record names (and IOC info) to it.
https ://github.com/ChannelFinder/ChannelFinderService
Create record name manifest during build David Bracey via Tech-talk
Re: Create record name manifest during build Mark Rivers via Tech-talk
Re: Create record name manifest during build Pierrick Hanlet via Tech-talk
Re: Create record name manifest during build David Bracey via Tech-talk
Re: Create record name manifest during build Johnson, Andrew N. via Tech-talk
Prev: Re: Create record name manifest during build Johnson, Andrew N. via Tech-talk
Next: Re: Create record name manifest during build Jure Varlec via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
ANJ, 24 Jul 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
