1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Create record name manifest during build
From: Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Fri, 24 Jul 2026 08:57:10 +0200
On Fri, 24 Jul 2026 at 08:24, Jure Varlec via Tech-talk <tech-talk at aps.anl.gov> wrote:
On 7/23/26 22:26, David Bracey via Tech-talk wrote:
> But I think we can’t wait until we launch the IOC - we may need to do it at build time.
Well, you don't need a fully functional IOC to get the list of records, the dbl command works before iocInit. So, you may be able to use the softIoc executable as a build-time tool. Just define the macros, load the databases, have dbl write to a file, and exit. Networking and such doesn't happen until iocInit, so using softIoc this way shouldn't be problematic. Probably ;)
Sweet!
And definitely low-effort and low-maintenance compared to unearthing the IRMIS crawlers...
The only thing... I'm not able to create a startup script that exits the softIoc after it loads databases and dumps the record list. Is there a way to do that? (Would make it a lot easier to include this in the build.)
Cheers,
~Ralph
Re: Create record name manifest during build Ralph Lange via Tech-talk
Re: Create record name manifest during build Anders Lindh Olsson via Tech-talk
Create record name manifest during build David Bracey via Tech-talk
Re: Create record name manifest during build Mark Rivers via Tech-talk
Re: Create record name manifest during build Pierrick Hanlet via Tech-talk
Re: Create record name manifest during build David Bracey via Tech-talk
Re: Create record name manifest during build Jure Varlec via Tech-talk
Prev: Re: Create record name manifest during build Jure Varlec via Tech-talk
Next: Re: Create record name manifest during build Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
ANJ, 24 Jul 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
