Folks,
asyn R4-46 is available:
These are the release notes:
devVxi11
Make VXI11 support (for VISA systems) optional. VXI11 is broken on RTEMS-5 and rarely required for real-time system IOCs. By default enabled via setting DRV_VXI11=YES in configure/CONFIG_SITE. (Except RTEMS-5.)
Thanks to Heinz Junkes for this.
Many changes to eliminate compiler errors and warnings on newer compilers.
Fixed an issue with late enabling of autoconnect where it would only attempt to connect once.
Changed drvAsynIPPort so that connection attempts are non-blocking using poll(). This prevents operations like setting the EOS from hanging the IOC startup for long periods if the device is not reachable.
Home:
https://github.com/epics-modules/asyn
Documentation:
https://epics-modules.github.io/asyn/
Re: EPICS Developers Meeting and Codeathon at Brookhaven, Oct. 19–23 Shroff, Kunal via Tech-talk
Re: CSS Phoebus integration Luis Alberto De Sousa Moreira via Tech-talk
2025
<2026>
Re: Using an EPICS documentation diagram in an academic apprenticeship report bob dalesio via Tech-talk
Java PVA client: connect directly to known IOC endpoint without any search (no UDP multicast/unicast, no TCP directed search) Usharani Kandula via Tech-talk
2025
<2026>
ANJ, 04 Aug 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
