You can turn on POSIX priorities for your IOC. Under that regime, the faster SCAN threads have higher priority and keep the desired timing.
To properly support this in the Asyn layer, you should also set your faster records to a higher PRIO. This will put them in separate port level queue, so they don't get stuck behind the low-priority slow records.
Cheers, ~Ralph
- spread database processing over a time interval Majer Karel via Tech-talk
Re: spread database processing over a time interval Sukhanov, Andrei via Tech-talk
Re: spread database processing over a time interval Simon Rose via Tech-talk
2025
<2026>
Re: spread database processing over a time interval Ralph Lange via Tech-talk
Phoebus on ARM64 Dudley, David via Tech-talk
2025
<2026>
